REquired Fields
Thread begun 3/26/2015 3:32 pm by nickj | Last modified 3/30/2015 9:43 am by Jason Byrnes | 2161 views | 3 replies |
nickj
REquired Fields
When I populate a menu field the pop up error notification for a required field does not appear on submit. I tried opening the validations server behavior and everything looks OK...
Thanks'
Nick
edit the default "select Size" option to have a blank value.
change:
<option>Select Size</option>
<option value="">Select Size</option>
for some reason, DW doesn't add the blank option, but it is needed for the required validation to trigger.
nickj
Thanks, that worked great! I was dreading a number of work arounds..
Nick
you're welcome.
