My images can't be found on a website that just went live
Thread begun 3/26/2015 7:20 am by russb335115 | Last modified 3/30/2015 10:21 am by Jason Byrnes | 3622 views | 5 replies |
russb335115
I just point a URL at a client's new website and all the images are now showing up as missing. The site is in the same folder the only thing that change is the url for the website. How do I update this?
you will need to adjust the paths for the images to look at the correct path
can you give a link to a page please? also where are the images stored?
russb335115
Here is the links:
This is for the live website address: antronix.com
This is the address I used as I was developing the website: http://s403739248.onlinehome.us/antronix/
Images where placed using PowerCMS so they are in the files folder and where ever CMS puts them.
It's the same folder the only thing that changed is the url.
the address for the images is pointing to a subfolder:
http://antronix.com/antronix/files/insert_MoCA_AMPs_2.jpg
the antronix.com address is pointing to the same subfolder.
the address for the images should not include the antronix folder:
http://antronix.com/files/insert_MoCA_AMPs_2.jpg
you will need to remove the antronix folder from the image paths.
russb335115
Does that have to be done image by image?
you could try an update on the contents table directly through phpMyAdmin using the replace function:
http://dev.mysql.com/doc/refman/5.5/en/string-functions.html#function_replace
the syntax would look like:
UPDATE pcms2_contents SET ContentValue = REPLACE(ContentValue,'/antronix/','/') WHERE ContentValue LIKE '%/antronix/%'
I Would strongly sugest backing up the table first.
