Can't get current state to work
Thread begun 8/29/2009 6:57 am by william279633 | Last modified 9/04/2009 10:27 am by william279633 | 5059 views | 8 replies |
william279633
I have read the messages in the forum about this but nothing seems to suggest an answer.
Here is the code for the Nav of my About page. When previewed all menus look and act the same. I spec'd a different BkGnd color in my menu.css file so it would show the iewer they are on the about page. - see the a.current code after the html.:
<div id="nav">
<ul class="level-0" id="cssmw">
<li><a href="index.htm">Home</a></li>
<li class="parent"><a href="#link">Portfolio</a>
<ul class="level-1">
<li><a href="painting.html">Painting</a></li>
<!--<li><a href="drawing.html">Drawings</a></li>-->
</ul>
</li>
<li class="current"><a href="#">About</a></li>
<li><a href="price.html">Price List</a></li>
<li><a href="contact.html">Contact</a></li>
</ul>
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 2}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 2}); }, true); }</script>
menu.css code for the a.current tag:
ul#cssmw > li.current > a.current {
background-color: ##7BA5AD;
color: #2D2B2E;
font-weight: bold;
text-decoration: none;
Can you suggest an answer?
William
Hard to tell what is wrong from the menu and CSS Snippet you have provided. can you post a link to a page that displays the error so I can troubleshot the problem in context.
william279633
page link
This post has been deleted.
william279633
page link
Jason,
Here is an example of a page from the site that doesn't respond with a current state. There is no error message just no high light color behind current menu for home page
The CSSMENU FOLDER is located at cssmw
home.html
Thanks for any help you can provide.
I attached the cssmw folder
WM
In the menu.css file try changing:
background-color: #7BA5AD;
color: #2D2B2E;
font-weight: bold;
ul#cssmw > li.current > a {
color: #2D2B2E;
font-weight: bold;
william279633
suggestion
Jason,
Thanks for taking the time to look at this. I replaced the code as suggested but still no background change for current state on page.
Wm
When I view source of your menu.css, I still see:
color: #2D2B2E;
font-weight: bold;
It needs to be changed to:
color: #2D2B2E;
font-weight: bold;
william279633
a partical solution
Jason,
Sorry, I was testing locally and didn't update the server. I was trolling around the forum and found an example of a site that had the current state working. Again i was doing this locally.
I added the class="link" to the <li> and class="link current" to the <ahref>link that is the current page. I followed the example and it worked on the level0 menu but not the level1 secondary menu.
this code remained the same:
color: #2D2B2E;
font-weight: bold;
<div id="nav">
<li class="link current"><a class="link current"href="index.html">Home</a></li>
<li class="link"><a class="link"href="painting.html">Painting</a></li>
<!--<li class="link"><a class="link"href="drawing.html">Drawings</a></li>-->
</ul>
</li>
<li class="link"><a class="link"href="about.html">About</a></li>
<li class="link"><a class="link"href="price.html">Price List</a></li>
<li class="link"><a class="link"href="contact.html">Contact</a></li>
</ul>
wm
If you try my suggestion, I believe it will work for all menu levels.
william279633
Jason,
By adding the claas="link current to the <li> and ahref of the level 1 link I got it to work for all menus. THanks for your help.
wm
<div id="nav">
<li class="link"><a class="link"href="index.html">Home</a></li>
<li class="link current"><a class="link current"href="painting.html">Portfolio</a>
<li class="link current"><a class="link current"href="painting.html">Painting</a></li>
</ul>
</li>
</ul>
