form element binding
Thread begun 3/25/2015 7:58 am by Jamie | Last modified 3/30/2015 10:44 am by Jason Byrnes | 2507 views | 5 replies |
Jamie
Hi Jason
On the attached page, have a couple of queries.
1. With the form elements, if I were to bind them to their relevant validated entry, would that screw up adding the buyers info to Paypal and/or the orders database?
2. I have added a dynamic coupon system but cant get the page to display the discoutn line in the cart nor make the discount to the total. Have also added link in the PM to the page in question
Jamie
1) no, that should not effect the checkout
2) I must be blind, I don't see a voucher code input? to troubleshoot though, I will need direct FTP access
Jamie
see PM re voucher code and fyi heres a screengrab of where the input is: http://prntscr.com/6lads5
on the checkout page, you have code to set a static CouponCode session based on the coupon code form element:
@session_start();
if((((isset($_POST["txtPromoCode"]))?$_POST["txtPromoCode"]:"") != "")) {
$_SESSION["PromoCode"] = "".((isset($_POST["txtPromoCode"]))?$_POST["txtPromoCode"]:"") ."";
all of the discount rulers are set up for other sessions like CouponIsPercent, CouponProduct and such, but there is no code in place to set those sessions.
It looks like only the rules have been created but not the code to set the sessions that are used by the rules.
Jamie
gotcha... got that working now, thanks for pointing me in the right direction.
the start / end date function doesnt seem to be working....the coupon code in the PM should not work as the start date is 01-01-2015 and the end date is 28-01-2015
also, I have bound the form elements to the validated entry and when applying the voucher code, the page refreshes but doesnt remember the form details....
I don't see where you have implemented start and end date.
in the coupon rules, you don't specify a start or end date, and in the recordset that is used to populate the session, the condition is set to look for Live = 1
nothing is setup for looking at a start or end date.
for the validated entries, it will work if you use the Checkout button to submit the form. the validation behavior on the confirm cart page is set to use the CheckoutWizard_submit button as the trigger, no validation will happen on filling in the voucher.
