Google Search in the Free Tools.
Thread begun 3/24/2015 10:18 am by Paul | Last modified 3/30/2015 9:11 am by Jason Byrnes | 4804 views | 9 replies |
Paul
Does the Google Search in the Free Tools, have the ability to pull from a MySQL database? Or do I need to build my own search functionality from DataAssist?
I followed the tutorial and installed it on a test page and searched by a date. No results showed up.
No, Google search cannot search your Database.
the point of google search is that it uses the Google search engine, it is akin to going to google and doing a search for your domain, except that it presents the google results on your web page.
to search your database, you need to use Data Bridge.
Paul
Thanks, Jason...
Has it gotten any easier in Data Bridge to make search and results pages? :-)
Is there a new tutorial?
Creating a search / results page using data Bridge is the same as it ever was.
see this tutorial:
http://www.webassist.com/tutorials/Create-a-search-page-that-displays-filtered-results
Paul
Thanks, Jason...I've used that tutorial before, but I am not searching for a group of products with categories, just dates of events.
I want to return results based on the date, not the date range. Please correct me if I am wrong, as I'm trying to do this by myself but keep stumbling.
My search comparison type is: Exact Match
Exact Match Search by Column: Date
Column type is: Date
New form field is: DateSearch and TEXT
The date field is formatted as: yyyy-mm-dd
I have the pages completed and they are working, but not showing any results. Do I have to have the person searching enter the date as yyyy-mm-dd? Would rather be able to search by Month Day, or even by selecting from a calendar view. But, if this is correct, how come I don't have any results?
See PM
Where you set the column type to date, it causes DB Search to reformat the date you enter to the yyyy-mm-dd hh:ii:ss format, so:
2014-11-07
becomes:
2014-11-07 00:00:00
which won't match your dates that don't have the hh:ii:ss information.
i changed the data type to text to fix the search.
Paul
Appreciate that Jason...
It works great...is there any way without screwing up the programming for the rest of the site, to be able to enter a date like: March 28, instead of yyyy-mm-dd?
Thanks again!
you mean in the search form right?
yes, you could do that, but on the results page, you need to add code to reformat the date. your search form has the date field named "DateSearch"
so add the following code at line 1 to reformat the date to use the yyyy-mm-dd format:
if(isset($_POST['DateSearch'])) {
$_POST['DateSearch'] = date("Y-m-d", strtotime($_POST['DateSearch']));
Paul
Jason,
For some reason, all webassist email is going into junk folder. Not sure why, I've added the domain to safe-senders.
Anyway, I did mean in the Search Form, yes. And you want me to paste the above code, above line 1 on the results.php page? Here is line 1:
<?php require_once('../Connections/connConejo.php'); ?>
And this new code will allow a person to enter in the search box: March 28 instead of 2015-03-28?
I can't say why tour system is flagging mail form web assist as junk mail, it could be any number of things form a setting in your email system to a setting on the pop server that is used for incoming mail.
Yes, the code would go on line 1 of the page.
it would work as long as the user added the year:
March 28 2015
that would be converted to:
2015-03-28
