cs6 for mac configuration and mamp
Thread begun 3/24/2015 8:57 am by software.current355386 | Last modified 3/25/2015 9:04 am by Jason Byrnes | 2998 views | 4 replies |
new to mac/mamp used dwcs6/xammp on windows,
what the best way to install/configure cs6 and mamp?
what will site definitionbe?? the more details you can supply will help
Afully detailed installation/configurationn crib sheet would be the perfect solution ...... hers hoping
installing mamp is pretty strait forward, download the installer form here:
http://www.mamp.info/en/
if you are familiar with XAMPP on windows, it's not really that different.
in XAMPP, it would create the site root as:
c:\xampp\htdocs
which mapped to the site address:
http://localhost
for each DW site you would create a subfolder of:
c:\xampp\htdocs
for example
c:\xampp\htdocs\site1
and adjust the web URL appropriatly:
http://localhost/site1
Same strategey applies with MAMP, the only difference is where the htdocs folder gets created.
in MAMP, the htdocs folder gets treated at:
Applications:Mamp;htdocs
create the subfolder for the site there:
Applications:Mamp;htdocs:site1
and the same web URL will link to it:
thanks
folooed directions by using the browse button to navigate to correct site files
noticed this put in / not the ; : indicated on your reply
could these prevent file to be displayed in safari directly or preview in browser --server cannot be found
if ispecify localhost:8888/sitname1/index.php it works when entering directly into bbrowsoer
hoow can i get rid of the 8888
in MAMP, go to the presences and select the ports tab to change the port used by Apache.
