Radio button value not saved correctly into database
Thread begun 3/24/2015 1:39 am by info4753 | Last modified 3/24/2015 10:36 am by Jason Byrnes | 2330 views | 5 replies |
info4753
I have a form with a radio button ("EintragInPatentafel") with two values, one for 1 one for 0. The value is correct inside the email but not correctly saved into the database (always 1). Can you please have a look at it? Files are attached. Thanks in advance.
in the insert behavior, you have set the data type for the radio button column to be:
Checkbox 1/0
this data type should be used for checkboxes only, not for radio buttons.
With a checkbox it can have a value or be blank, so a checkbox would send either the checked value or "" meaning no value. the Checkbox 1/0 data type converts the blank value to 0. and converts the checked value to 1. doesn't matter what the checked value is it could be yes, and it will get converted to 1.
with your radio button, you are sending either 0 or, no blank value. when 0 is selected it gets converted to 1, because it is not blank.
you should use the integer data type instead.
info4753
Thanks Jason.
You mean I can keep radio button value = 1 for the yes button, and value = 0 for the no button, and use integer value for the insert behavior?
yes, that is correct.
info4753
Muchos gracias Jason.
you're welcome.
