mysqli and mysql_num_fields
Thread begun 3/19/2015 7:12 am by Jediha | Last modified 5/01/2015 11:33 am by Ray Borduin | 4029 views | 6 replies |
Jediha
On a page I want to use a mysql recordset. But somewhere in the code I need to know how many columns there are in the database table.
I used to use mysql_num_fields($recordsetname)
What do I need to use know with mysqli - object?
Thanx!
to write the number of records in a MySQLi recordset to the page, there is a server behavior.
on the Server Behaviors panel, click the Plus button and select WebAssist -> MySQLi -> Display record Count -> MySQLi Display Total Records.
Jediha
Hi, thank you for replying, but that was not what I asked.
I need a code to let the script know how many columns there are in the database table and there fieldnames : (c_id | c_titel | c_text | c_date | c_publish) -> makes 5 columns
Ok, sorry, i misunderstood
use this to writ eh number columns returned from the query:
<?php echo sizeof($recordsetName->Results[0]); ?>
where recordsetName is the name of the recordset.
Jediha
Thank you, just one other related question:
When I loop the number of columns inside a loop from a mysqli recordset I want to get the field name(columnname). With the old php mysql it was possible with: 'mysql_field_name'.
Is there a replacement for within the mysqli class?
Thank you!
The column names are the key values of the returned array.
I think you are trying to do something like:
if (sizeof($Recordset1->Results)>0) {
<table>
<tr>
foreach ($Recordset1->Results[0] as $key=>$val) {
  <th><?php echo($key); ?></th>
</tr>
for ($x=0$x<sizeof($Recordset1->Results); $x++) {
    <tr>
foreach ($Recordset1->Results[$x] as $key=>$val) {
        <td><?php echo($val); ?></td>
    </tr>
</table>
} else {
no results found
Jediha
Thank you Ray,
that was what I was looking for. I knew there was an array, just didn't know exactly how to get the data from it.
Thanx!
Hans
