Show text only if date record added is less than 150 days from another date in database
Thread begun 3/18/2015 3:46 pm by Mags | Last modified 3/18/2015 3:55 pm by Mags | 1844 views | 1 replies |
Mags
I have two date fields in my database, one is a date which is manually added (StagingDate) and the other is a timestamp which records when the record is added (DateAdded). I'm using a Show If to display text only if a record has been added 150 days or less before the StagingDate. I have the following syntax, and I want to add in a "+150 days" to the DateAdded bit but I'm suffering from "code blindness" because I can't get the syntax right! Can you help? Something like this:
<?php if(date("Y-m-d", strtotime($row_WADAclients['StagingDate'])) < date("Y-m-d", strtotime($row_WADAclients['DateAdded']"+150 days"))) { // Show if column... ?>
Text to display
<?php } // Show if column... ?>
Mags
I think I figured it out - for anyone else wondering, this works:
<?php if(date("Y-m-d", strtotime($row_WADAclients['StagingDate'])) <= date("Y-m-d", strtotime($row_WADAclients['DateAdded'] . "+150days"))) { // Show if column... ?>
