My form is not validating my file manager or select menu
Thread begun 3/18/2015 12:54 pm by jo271221 | Last modified 3/23/2015 9:29 am by Jason Byrnes | 2570 views | 7 replies |
jo271221
My form is validating the caption but not the 1st image (file manger field) or my Select Vendor (select menu) Details attached.
Thank you in advance.
I am not able to access the FTP server to troubleshoot, see PM
jo271221
Sorry there should be a www in front of the website name. I updated the doc.
I am still not able to access the site, i get the same 530 Login authentication failed response:
jo271221
Revised credentials attached
for the vendor, make sure the Select Vendor option has an empty value:
change:
<option selected>Select Vendor</option>
<option value="" selected>Select Vendor</option>
for the file manager, there is no validation set up. the server validatin has only 3 validations set:
Requered validation for the caption filed
Requered validation for the custom filter filed (which is the vendor select list)
Date Time validation for the featuredate filed.
if you want to make the file manager field required, you need to edit the server validations to add the require validation for it.
jo271221
Thank You!
you're welcome.
