Data Bridge 122 not installing on DW CC 2014
Thread begun 3/18/2015 9:27 am by pat356751 | Last modified 3/18/2015 10:41 am by Jason Byrnes | 2446 views | 4 replies |
pat356751
Data Bridge 122 is not installing properly on a Mac OS 10.10. I'm getting an error message, see attached. After Dreamweaver boots up, Webassist tries to finish the install but gets stuck at stage 1 of the download process. I have to force reboot Dreamweaver to continue. I have tried trouble shooting the problem with the Commen Installer Issues suggestions with no success.
How much time are you giving the web assist installer to complete? depending on your connection speed, you may need to wait a few minutes.
Uninstall Data Bridge from the extension manager, install it again, and give the WebAssist installer more time to complete.
pat356751
Web assist finished the download but I'm still getting the error message. Also, I'm getting an error message that there has been too many activations when I enter the serial no..
pat356751
Authentication is now working but the javascript error message continues.
try recreating the users configuration folder, then installing again.
to locate the users configuration folder, see the common installation issues page:
once you locate the configuration folder, rename it, then open Dreamweaver to recreate it.
next close DW, and open the Extension manager. remove the extensions, then install them again.
