Echo setQuery
Thread begun 3/17/2015 11:13 am by Steve | Last modified 3/17/2015 12:36 pm by Jason Byrnes | 1702 views | 3 replies |
Steve
Echo setQuery
Hello,
What is the method to echo the setQuery?
For instance, I'm passing a Post from a Select List to render a new recordset but want to double checked the final formed query.
$Records = new WA_MySQLi_RS("Records",$Domains_i,1);
$Records->setQuery("SELECT * FROM inv_task WHERE inv_task.tsk_type = ?");
$Records->bindParam("i", "".$_POST['selinvoiceType'] ."", "4"); //target
$Records->execute();
echo setQuery; directly after the line does not render anything to the screen. We could do this with traditional recordset generations but not sure how to attain the same goal with MySQLi
<?php echo $Records->debugSQL(); ?>
Steve
Perfect! Thank you Jason...
you're welcome.
