error data bride
Thread begun 3/17/2015 10:44 am by QuiruNet | Last modified 3/17/2015 11:37 am by Jason Byrnes | 2052 views | 5 replies |
QuiruNet
error data bride
when i use show region utility. Happens. thanks
Notice: Undefined index: pass in /var/www/vhosts/mueblesvillamor.es/httpdocs/mi-cuenta/index.php on line 379 Notice: Undefined index: error in /var/www/vhosts/mueblesvillamor.es/httpdocs/mi-cuenta/index.php on line 386 Notice: Undefined index: not in /var/www/vhosts/mueblesvillamor.es/httpdocs/mi-cuenta/index.php on line 393
by default DW does not use asset() which it should for GET variables.
in the show region behavior, when you select a URL Variable binding, the code will look like:
<?php echo $_GET['error']; ?>
you should change that to use asset to prevent undefined index errors if the URRL variable is not set:
<?php echo(isset($_GET['error'])?$_GET['error']:""); ?>
this is a limitation to the DW Bindings panel.
QuiruNet
info
I have to include the code here:
if ("".$_GET['pass'] ."" == "1") { // WebAssist Show If
<div class="pass">TE HAS DADO DE ALTA CON EXITO EN NUESTRA PÁGINA </div>
} // ("".$_GET['pass'] ."" == "1")
you don't need to edit the code, you can edit the behavior.
in the behavior, when you select the pass binding, the biding code will look like:
<?php echo $_GET['pass']; ?>
change that to include the asset function:
<?php echo(isset($_GET['pass'])?$_GET['pass']:""); ?>
QuiruNet
thanks
Thanks, it works.
Is a dreamweaver problem?
yes, the DW Bindings panel doesn't write the asset code, it leaves that off, so if you have a page that references a URL binding but it doesn't exist, it will cause that error.
