search filters showing previous
Thread begun 3/17/2015 5:26 am by Kumel | Last modified 3/17/2015 12:46 pm by Kumel | 2721 views | 5 replies |
Kumel
ref:http://eta-logistics.com/brokerage.php
search for boats.
when boats are been searched & then if page is closed & opened again then previous results are shown & not all results.
i dont want previous results to be shown. file attached.
when a search is done, it is saved to a session, this is so that pagination can work properly.
you can add a reset results link to the page to clear the previous session, See this page for details on resetting the search results:
http://www.webassist.com/forums/showpost.php?p=93270&postcount=2
Kumel
so it has to be made manually. by clicking.
i set up everything but bit confused here:
my page is: brokerage.php
which is here: http://www.eta-logistics.com/brokerage.php
now the session is:
WADbSearch1_brokerage_results
so to clear it must be : <a href="brokerage.php?reset=true">Clear Search</a>
or from above link given <a href="productsResults.cfm?reset=true">Clear Search</a>
for
on the results page add a link to clear the search passing the reset qurystring variable:
in which my case will be : <a href="brokerage_results.cfm?reset=true">Clear Search</a>
So which one should be used.
when i used <a href="brokerage_results.cfm?reset=true">Clear Search</a>
page seems to break.
when i use this : <a href="brokerage.php?reset=true">Clear Search</a>
page reload but all results still not shown. so when i refresh all results are shown.
where m i wrong?
Kumel
is this is the way then its good to have two different pages for it. one search page & another results page rather than everything in one page.
yes, you can have the search and results page be separate.
just make sure the search form action is to go to the results page.
Kumel
yeah have done that.
thanks anyways
