Error on DFP/DA Insert page
Thread begun 8/28/2009 1:19 pm by jspencer190495 | Last modified 8/31/2009 3:09 pm by Jason Byrnes | 4258 views | 3 replies |
jspencer190495
I'm new to Web Assist software, so this may be a simple problem that I'm missing. I built a page to upload a file and insert it into a database following the PDF instructions for doing this. When I try to upload a file, I get this error:
Request object, ASP 0207 (0x80004005)
Cannot use Request.Form collection after calling BinaryRead.
/admin/Files_Insert.asp, line 21
Line 21 has this code:
WA_fieldValuesStr = "" & cStr(WA_DFP_UploadStatus.Item("WA_UploadResult1").serverFileName) & "" & "|" & "" & cStr(cStr(Request.Form("screenname"))) & ""
Any idea what's the problem? I went through the building process twice, thinking that since this was my first try with WebAssist software, maybe I missed or screwed up a step, but I got the same result the second time.
Jon
When using Digital FDile pro With A DataAssist insert page, you need to rebind all of the form fields in the Insert Record Server Behavior after applying DFP.
double Click the Insert Record Server Behavior and select each Database Column that will get a value. Click the lightning bolt and expand the form collection. Then Select the corresponding form element.
This modify the code for the binding and change it from using the Request.Form Collection to using the WA_UploadObj.Form Collection instead.
jspencer190495
Thanks. That fixed the Insert page.
Now I'm getting the same error on the Update page but I must be making the wrong selection because the error is persisting. Is the Update page treated differently for any reason?
Jon
if you are getting the same error, there is still a Request.Form reference on the update page.
In the error it will tell you the line number where the error is occurring, look at that line number for Request.Form and change it to WA_UploadObj.Form
