Failure to add a database
Thread begun 3/15/2015 5:51 pm by Ian | Last modified 3/17/2015 10:06 am by Jason Byrnes | 1222 views | 1 replies |
Ian
I am producing databases accessible via web for local church. At present there are two database - terrier (Register of church property) and graveyard. The terrier section (basically a set of folders and sub-folders) is working fine and I can add all the WebAssist code I need, but when I work on the second section to access the graveyard data, whatever page I try to add a MySQLi record set, the Recordset box appears, saying "Loading" but eventually Dreamweaver fails to respond and I have to close it down.
I'd be grateful for any help.
Do you have a MySQLi connection set up for the second Data base?
can you open the connection and test it successfully?
Go to the database tab to see defined connections and test them.
