Problem with activation os MysqLi server behaviors
Thread begun 3/15/2015 4:13 am by Oscar (Xavia Digital) | Last modified 4/10/2015 10:46 am by Ray Borduin | 6529 views | 13 replies |
I've been using the extension properly moved for weeks, but now I activation window appears.
When I enter the serial number I get the following error in red:The serial number you entered is incorrect.
I tried to DC 2014 and DC. What can i do?
Thank You
Same problem with all extensions
I have the same problem on all extension of webassist. Definitely activations current system has its problems lately. It is assumed that this was a problem already solved, and already several times that we could work on this issue with the consequences that entails with some clients ...
We fixed the issue with activation on Sunday evening, the activation server should be back up.
Stil does not work
In our case still does not work, tested in dreamweaver 2014.1 and CC.
Attached screens both sides of activation, the first gives ok and the second error.
Greetings!
Try reseting your activations.
once logged in, go to the All My Downloads page:
http://www.webassist.com/account/downloads.php
and click the reset activations button.
I had already tried and the problem persists. We have also reinstalled the extension, and the problem persists.
You're screen shot shows that it is using the serial number for Data Bridge, but your subject says you are trying to activate MYSQLi?
For activating MySQLi, you will need to use the MySQLi serial number from your account.
Brad Lawryk
I am also having this issue on two different machines. Both Mac ... one a Mackbook the other an iMac
Post the serial you are trying in the private area and I'll try to reproduce the issue to look into it further.
Brad Lawryk
Serial in Private .....
