creating a wish list for ecommerce
Thread begun 3/12/2015 8:02 am by Christopher West | Last modified 1/18/2016 11:19 am by Ray Borduin | 12957 views | 5 replies |
Hi there, I was wondering if you could detail the process or if its possible with the mysqli extension.
I have an ecommerce website and my client wants a wish list page. So I assume, that the way it would work if if the customer views a product the ID of that product will be saved to a cookie on page load. And every subsequent product view the additional product ids will also be saved to a cookie - for this part I assume it would be ONE cookie and that all these product ids will be inside an array.
Then on the actual wish list page the recordset would then look at the cookie array and load them all in.
Is this process one way of doing developing this feature? are there any other way?
And could you point me in the direction to :
(a) saving a product id into a cookie array
(b) loading the cookie array into a recordset
Regards
Chris
for a wish list, you wouldn't save the info to a cookie, i wouldn't do it that way, i would saver the info to a wishlist database table.
first off, before they can add an item to a wishlist, they would need to be logged in. the Security Assist Authentication will save the logged in users ID to a session variable.
on the product page, add ash Add to Wish list button. And add an insert record behavior. the insert record behavior should be set to save the items ID to the wish list table, and the users ID
on the page to display the wishlist, you can use a recordset to search the wishlist table based o the users ID and join the products table to show the products for the logged in user.
My apologies...(lack of sleep) I should have mentioned it to be a "recently viewed products" section (that will be displayed at the bottom throughout the website). So this would work on the basis that its not a logged in user. So is my understanding still correct for that feature? and if so what would be the processing in terms of loading the product ids into a cookie array and then loading them into the recordset?
Chris
ok, well thats a totally different can of works.
use the Set Cookie value server behavior on the item details page.
on the bindings panel, make sure there is a URL variable binding for the variable used to populate the details page. for example, if the variable that passes the ID is named id:
details.php?id=12
make sure to have a URL variable named id
in the Set Cookie value behavior, click the lightning bolt next to trigger and select the id URL variable.
set the cookie name to viewedItems
and for the value, use the following code:
<?php echo(isset($_COOKIE['viewedItems'])?$_COOKIE['viewedItems'].", ":""); ?><?php echo $_GET['id']; ?>
this will set the cookie with a comma separated list of the ID's.
now using the MySQLi recordset, use the advanced query builder to create the recently Viewed recordset using the IN comparison on the ID column and select the viewedItems cookie as the variable
Hi, got round to trying this but having problems.
Just so that you know in the URL I am using the product name (for SEO value) but its only displaying 1 product from the cookies (also I need to find a way to only store the cookie if the product doesnt already exist in the cookie...otherwise there will be many of the same product in the cookie array as a custom could repeatedly go to the same product)
ok heres the code I have at the moment:
if ((isset($_GET['Product']) && $_GET['Product'] != "")) {
setcookie("viewedProducts""".(isset($_COOKIE['viewedProducts'])?$_COOKIE['viewedProducts'].", ":"")  ."".$_GET['Product']  .""time()+(60*60*24*30), "/"""0);
$rsProduct
= new WA_MySQLi_RS("rsProduct",$ecartdb,1);
$rsProduct->setQuery("SELECT * FROM products WHERE ProductName = ?");
$rsProduct->bindParam("s""".(isset($_GET['Product'])?$_GET['Product']:"")  ."""-1"); //colname
$rsProduct->execute();?>
$rsViewedProducts
= new WA_MySQLi_RS("rsViewedProducts",$ecartdb,1);
$rsViewedProducts->setQuery("SELECT * FROM products WHERE ProductName = ?");
$rsViewedProducts->bindParam("s""".$_COOKIE['viewedProducts']  ."""-1"); //colname
$rsViewedProducts->execute();
while(!$rsViewedProducts->atEnd()) {
<a href="product.php?Product=<?php echo($rsViewedProducts->getColumnVal("ProductName")); ?>" class="b-link-fade b-animate-go">
<div class="item4"><img  src="images/products/<?php echo($rsViewedProducts->getColumnVal("ProductImage")); ?>" alt=""  class="responsive-image"></div>
<div class="b-wrapper">
<h2 class="b-from-left b-animate b-delay03"><?php echo($rsViewedProducts->getColumnVal("ProductName")); ?></h2>
<p class="b-from-right b-animate b-delay03">£<?php echo($rsViewedProducts->getColumnVal("ProductPrice")); ?></p>
</div>
</a>
$rsViewedProducts
->moveNext();
$rsViewedProducts->moveFirst(); //return RS to first record
NOTES: In the Edit Variable box on the MySQLi recordset if I check the box "comma-seperated list" I get a PHP error in browser.
here is th ecode it creates by selecting the checkbox (the value that changes is bindParam("sl", ..........
$rsViewedProducts
$rsViewedProducts->bindParam("sl""".$_COOKIE['viewedProducts']  ."""-1"); //colname
When you mentioned about using the IN comparison I did look that up on Google, but was unsuccessful in finding the correct way to do it..
Please help, as nearly there.
Also is this method still ok in using the Product Name in the URL since I would rather do it that way then product ID.
Chris
This is too complex to debug in a forum post. You will need to sign up for premier support so I can work with the files directly.
