Data Bridge v1.2.2 Released
Thread begun 3/11/2015 9:30 am by Jason Byrnes | Last modified 11/13/2018 6:30 am by Ray Borduin | 8091 views | 8 replies |
Data Bridge v1.2.2 has been released. The update includes the following bug fixes:
* Corrected an issue that caused Dreamweaver to crash under OSX Yosemite when running the DataAssist Create Pages wizard.
* Corrected an issue that caused an error to occur when using the ‘no button’ design option when creating pages under OSX.
* Corrected an issue that caused activation to appear when launching Framework Builder if eCart wasn’t installed.
The full version history can be viewed on the Data Bridge download page.
Chris Bernard
xml parsing error
Hi I keep getting this error when trying to install new version of Data Bridge, I also get this error when I try to remove the extension as well "Failed to parse XML file error for C:\Chris Bernard\AppData\Roaming\Adobe\Dreamweaver CC 2014.1\en_US\Configuration\Menus.xml. The extension will not be installed"
weboholic
Close DW, rename Menus.xml to something else, start DW and close again. After that you are able to install the extension.
--web
muhammad
upgrade version msqli
Have you been to support the upgrade version msqli
Data Bridge does not produce MySQLi code from the wizard in this build.
randyrie405335
Stability of Databridge v2.2.x Release
Will the final release of DataBridge v2.2.x be COMPLETELY compatible with Dreamweaver CS6 running on a Macbook Retina 15 inch (mid-2014) with OS X 10.13.6 (64 bit)? The betas I've been using for the past four years frequently crashed DWCS6 which is a 32 bit application. I DO NOT WANT TO UPGRADE TO ANY OF THE CC (64 bit) versions of Dreamweaver just to use the latest version of Databridge.
Crashes can happen in Dreamweaver. We hope to be completely compatible, but I really can't make any guarantees since every system is different. It probably varies based on graphics card, RAM, OS version, DW Version, and processor. We will do our best to make it work on all platforms.
anonymous
Data Bridge (MySQLi)
Is this new MySQLi version of Data Bridge compatible with Dreamweaver CC 2019
Also is there a complete and full list of extensions/features included, I can see general info but not full list ??
Is the a free trial ?
Thnaks
Free trials are not available, but there is a full refund for any reason for 15 days after purchase.
There is not a complete list of all Server Behaviors, but if you click the "learn a whole lot more" link next to the MySQLi Server Behaviors listing on the Data Bridge page it will show you most of the Database interaction server behaviors. It won't include all of the file management, email, validation, and other server behaviors as well as the wizards and other features.
