pagination help
Thread begun 3/11/2015 5:46 am by Kumel | Last modified 3/12/2015 2:47 pm by Jason Byrnes | 4563 views | 13 replies |
Kumel
pagination help
I got a result page. i customized it to my template.
Now i m unable to add pagination. i added at the end of the page but doesn't seem to show.
Can you take a look?
www.shrishtiart.com/artworks.php
Only 30 results are shown there, i wanna show next, prev buttons at bottom.
artworks_results.php orignal page by data bridge.
these are the codes for pagination:
<div class="WADAResultsNavigation">
<div class="WADAResultsCount">Records
<?php echo ($startRow_WADAartworks + 1) ?>
to
<?php echo min($startRow_WADAartworks + $maxRows_WADAartworks, $totalRows_WADAartworks) ?>
of
<?php echo $totalRows_WADAartworks ?>
</div>
<div class="WADAResultsNavBottom">
<table border="0" cellpadding="0" cellspacing="0" class="WADAResultsNavTable">
<tr valign="middle">
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($pageNum_WADAartworks > 0) { // Show if not first page ?>
<a href="<?php printf("%s?pageNum_WADAartworks=%d%s", $currentPage, 0, $queryString_WADAartworks); ?>" title="First"><img border="0" name="First1" id="First1" alt="First" src="WA_DataAssist/images/Pacifica/Refined_first.gif" /></a>
<?php } // Show if not first page ?></td>
<a href="<?php printf("%s?pageNum_WADAartworks=%d%s", $currentPage, max(0, $pageNum_WADAartworks - 1), $queryString_WADAartworks); ?>" title="Previous"><img border="0" name="Previous1" id="Previous1" alt="Previous" src="WA_DataAssist/images/Pacifica/Refined_previous.gif" /></a>
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($pageNum_WADAartworks < $totalPages_WADAartworks) { // Show if not last page ?>
<a href="<?php printf("%s?pageNum_WADAartworks=%d%s", $currentPage, min($totalPages_WADAartworks, $pageNum_WADAartworks + 1), $queryString_WADAartworks); ?>" title="Next"><img border="0" name="Next1" id="Next1" alt="Next" src="WA_DataAssist/images/Pacifica/Refined_next.gif" /></a>
<?php } // Show if not last page ?></td>
<a href="<?php printf("%s?pageNum_WADAartworks=%d%s", $currentPage, $totalPages_WADAartworks, $queryString_WADAartworks); ?>" title="Last"><img border="0" name="Last1" id="Last1" alt="Last" src="WA_DataAssist/images/Pacifica/Refined_last.gif" /></a>
</tr>
</table>
</div>
</div>
Which line should i add these codes?
Kumel
well i made some changes on my artworks.php i guess few things were missing.
$maxRows_WADAartworks = 5;
$pageNum_WADAartworks = 0;
if (isset($_GET['pageNum_WADAartworks'])) {
$pageNum_WADAartworks = $_GET['pageNum_WADAartworks'];
$startRow_WADAartworks = $pageNum_WADAartworks * $maxRows_WADAartworks;
mysql_select_db($database_con1, $con1);
$query_WADAartworks = "SELECT * FROM artworks ORDER BY `position` ASC LIMIT 40";
$WADAartworks = mysql_query($query_WADAartworks, $con1) or die(mysql_error());
$row_WADAartworks = mysql_fetch_assoc($WADAartworks);
$totalRows_WADAartworks = mysql_num_rows($WADAartworks);
if (isset($_GET['totalRows_WADAartworks'])) {
$totalRows_WADAartworks = $_GET['totalRows_WADAartworks'];
} else {
$all_WADAartworks = mysql_query($query_WADAartworks);
$totalRows_WADAartworks = mysql_num_rows($all_WADAartworks);
$totalPages_WADAartworks = ceil($totalRows_WADAartworks/$maxRows_WADAartworks)-1;
artworks.php is attached. but pagination is not visible on the page
Kumel
pvt msg.
see pm
Kumel
pvt
i moved the pagination outside of the portfolio wrapper to fix the issue.
Kumel
thanks but i find this pagination a bit difficult. any idea on how to make it to 1-2-3-4-5...... ?
I feel the best is load more key when you click next set of records appear.
I hope you can help me out with that.
Kumel
but the pagination doesn't seem to actually work. when i click next or keep clicking next last or so. doesn't seem to show relevant data. same data is shown all the time.
your page was missing the code to implement the paging in the recordset. I updated the recordset to fix it.
