Undifined variable
Thread begun 3/10/2015 2:20 pm by rgolfer | Last modified 3/11/2015 11:09 am by rgolfer | 3095 views | 6 replies |
rgolfer
Undifined variable
Hi there, I seem to be getting random Undefined variable errors when going to my shopping cart detail page. I mean random as sometimes I can go to the item and it works fine but most of the time it comes up with the error below. And it seems to matter which item it is as well. It was a couple specific items so I thought deleting them and setting them up again would work but that didn't help. All of the "missing" variables seem to be accounted so I'm a little perplexed as to why this is coming up. Do you have any ideas as to what is causeing this?
Warning: Missing argument 9 for toyocart1_ItemDefinition::toyocart1_ItemDefinition(), called in C:\wamp\www\support\WA_eCart\WA_eCart_Definition_PHP.php(556) : eval()'d code on line 1 and defined in C:\wamp\www\support\WA_eCart\toyocart1_PHP.php on line 161
Call Stack
Time
Memory
Function
Location
1 0.0002 363064 {main}( ) ..\Tcart.php:0
2 0.0076 416136 WA_eCartDefinition->GetContent( ) ..\Tcart.php:8
3 0.0076 416136 WA_eCartDefinition->Session_GetContent( ) ..\WA_eCart_Definition_PHP.php:72
4 0.0079 422968 eval( '$nextItem =new toyocart1_ItemDefinition("185", "BFAT2", "Open Country A/T II
Open Country A/T II", "BFAT2.jpg", "0", "1", "0", "Fran�");' ) ..\WA_eCart_Definition_PHP.php:556
5 0.0079 424280 toyocart1_ItemDefinition->toyocart1_ItemDefinition( ) ..\WA_eCart_Definition_PHP.php(556) : eval()'d code:1
( ! ) Notice: Undefined variable: itemCoop in C:\wamp\www\support\WA_eCart\toyocart1_PHP.php on line 171
Call Stack
Time
Memory
Function
Location
( ! ) Warning: Missing argument 7 for toyocart1_ItemDefinition::toyocart1_ItemDefinition(), called in C:\wamp\www\support\WA_eCart\WA_eCart_Definition_PHP.php(556) : eval()'d code on line 1 and defined in C:\wamp\www\support\WA_eCart\toyocart1_PHP.php on line 161
Call Stack
Time
Memory
Function
Location
4 0.0084 423976 eval( '$nextItem =new toyocart1_ItemDefinition("aise/French", "100", "14260216810213", "0", "0", "1 BFAT2 (185)");' ) ..\WA_eCart_Definition_PHP.php:556
5 0.0084 425168 toyocart1_ItemDefinition->toyocart1_ItemDefinition( ) ..\WA_eCart_Definition_PHP.php(556) : eval()'d code:1
( ! ) Warning: Missing argument 8 for toyocart1_ItemDefinition::toyocart1_ItemDefinition(), called in C:\wamp\www\support\WA_eCart\WA_eCart_Definition_PHP.php(556) : eval()'d code on line 1 and defined in C:\wamp\www\support\WA_eCart\toyocart1_PHP.php on line 161
Call Stack
Time
Memory
Function
Location
( ! ) Warning: Missing argument 9 for toyocart1_ItemDefinition::toyocart1_ItemDefinition(), called in C:\wamp\www\support\WA_eCart\WA_eCart_Definition_PHP.php(556) : eval()'d code on line 1 and defined in C:\wamp\www\support\WA_eCart\toyocart1_PHP.php on line 161
Call Stack
Time
Memory
Function
Location
( ! ) Notice: Undefined variable: itemPrice in C:\wamp\www\support\WA_eCart\toyocart1_PHP.php on line 169
Call Stack
Time
Memory
Function
Location
( ! ) Notice: Undefined variable: itemLanguage in C:\wamp\www\support\WA_eCart\toyocart1_PHP.php on line 170
Call Stack
Time
Memory
Function
Location
Call Stack
Time
Memory
Function
Location
Log out-fin de session
Profile-profil
Admin
this error means that the add to cart button was generated, then you edited the cart object to add more columns.
any time you add more columns, you need to edit each add to cart button instance on your site to have the code regenerated.
rgolfer
Hi Jason, Thanks for the quick response. I thought I set up everything from the start but who knows I have made several alterations to the site so you are probably right.
So I went in to my details page. It's the only place I have a "add to Cart" button for this cart. I opened up the add to cart function and updated it. I am still getting a similar error.
I'm seeing a bit of a pattern here though. It seems to only happen with the products with a French description. And for some reason on those items an extra line is added to the cart (see screen shot ... cart_extraline.JPG). When I delete these lines the page error goes away. I'm trying to see if taking out the special characters will help.
Just an update on above ... this error does only happen when it is a item marked as French. All the English items have French descriptions so could it be another setting I have made? The only other thing is that this is looking at two different databases. Wondering if there is a conflict there.
What I am noticing as well is that the Coop column when it is a 3 digit 100%, this is when this happens but only in the French.
I'm not sure what is causing this at this point but I have simply gone and edited each database entry removing special characters in the language description and then retyping the 100 for 100% coop. Strange but as I do this it then works.
rgolfer
Hi Jason,
I just finished cleaning up the database, reentering all the numbers in the coop field. I have double and triple checked since doing this and i can't re-create the error. I have asked someone to try it off site but haven't heard from them yet. I even tried adding some new items in French with some French characters etc. and still couldn't get it to come up. Bottom line is I'm not sure I can recreate the issue. Could the errors simply be because the format in the database was incorrect?
"Could the errors simply be because the format in the database was incorrect?"
Sure, could be that, or could be the character set for the connection.
If you can reproduce the error again, let me know and I will take a look.
rgolfer
Thanks for your time. I'll keep trying, If it comes back up I'll get back to you.
Character set is UTF-8 on all pages. and utf8_general_ci for the database
