Form isn't sending email - no errors - just not sending email
Thread begun 3/09/2015 4:38 pm by sandy170299 | Last modified 3/10/2015 1:17 pm by sandy170299 | 3741 views | 8 replies |
sandy170299
http://ribbonfair.com/contact-us.php
The form on this page isn't sending emails. I've tried different browsers, and it's just not sending emails.
Thank you.
looks like it is failing validation.
send a copy of the page please.
sandy170299
See attached.
in the server validation, you have the wrong name for the captcha session.
the code that creates the captcha image:
<img src="webassist/captcha/wavt_captchasecurityimages.php?field=captcha_2&amp;font=fonts/MOM_T___.TTF" alt="Security Code" class="Captcha" />
uses the filed URL variable as the captcha session name. the naming convention is:
captcha_<FieldURL Variable>
in the code, the url variable is:
field=captcha_2
so the name of the captcha session will be:
captcha_captcha_2
change line 17:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["captcha"])?$_POST["captcha"]:"")) . "",((isset($_SESSION["captcha_captcha"]))?strtolower($_SESSION["captcha_captcha"]):"") . "",true,6);
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["captcha"])?$_POST["captcha"]:"")) . "",((isset($_SESSION["captcha_captcha_2"]))?strtolower($_SESSION["captcha_captcha_2"]):"") . "",true,6);
sandy170299
It still didn't send the email, and it didn't redirect to the thank you page, either.
sandy170299
see PM...Thank you.
the trigger for universal email is set to use a submit button named:
AppointmentRequest_submit
but the button on your form uses a different name.
i updated the trigger code to use the correct button name
sandy170299
Thank you. I don't remember changing the name of the submit button, though...??? Weird. :)
