mySQli AND OR bug errors?
Thread begun 3/09/2015 1:28 pm by Warrio | Last modified 3/12/2015 2:20 pm by Jason Byrnes | 5815 views | 11 replies |
Warrio
I have an SQL statement that works with parameters, I'm trying to add to the statement with fields that reference one of the earlier parameters which fails with "Unknown Column"
The same statement worked in the old version mySQL
See attachment
Cheers
The problem is that you are reusing the paramVoucherID parameter.
a defined parameter can only be used once in the where clause. if you need to use the same perimeter settings more than once, you need to create a separate perimeter with those settings for each instance.
This is true for a standard DW recordset also.
Warrio
Thanks Jason
But not true of the standard DW, the code below works perfectly well on the old page and brings up no errors.
I tried creating paramVoucherID1 paramVoucherID2 and so on for the parameter that is required in a number of places, however it still produces the same error
Cheers
Norman
Old Working Code
SELECT view_coupons.Discount, view_coupons.VoucherCode
FROM view_coupons
WHERE ((view_coupons.catItemId=paramItemID AND (view_coupons.VoucherCode=paramVoucherID) ) OR ((view_coupons.catItemId= paramGrpID)) AND ((view_coupons.catalogueID=16) AND (view_coupons.VoucherCode=paramVoucherID)) OR ((view_coupons.catItemId= paramBrandID)) AND ((view_coupons.catalogueID=16) AND (view_coupons.VoucherCode=paramVoucherID))OR((view_coupons.VoucherCode=paramVoucherID) AND view_coupons.VoucherTypeID=4))
I'm my experience, Dreamweaver does not allow you to reuse parameter names, but i'm not going to argue the point.
please send a copy of the page with the MySQLi recordset on it that is causing the error and a dump of the table structure so that I can recreate the issue on my end to troubleshot.
Warrio
Thanks for the quick reply Jason
Attached are the files
Cheers
1) the page you sent has a number of recordset on it, which one is the problem recordset?
2) The SQL Dump you sent does not include the create table statement, so I do not have the table structure.
Warrio
Sorry Jason,
I was away with the fairies the other day, up far too early.
rsCoupon is the one I'm referencing, it's a view of two tables vouchers and voucher types
There are two tables and a view attached
Cheers
Norman
but on the page which is the recordset that is giving the error so I now what to look at to reproduce.
Warrio
Hi Jason
rsCoupon is the is the name of recordset, it's data is sourced from view_coupons.
The purpose is to return from the coupon value entered on the page, a discount for either a single item, items from categories or items from brands or a global discount.
Cheers
Norman
I'm not able to reproduce with the page you sent.
From what i see in the view, it only uses the vouchers table:
CREATE
DEFINER = 'root'@'127.0.0.1'
VIEW catalogues.view_coupons
AS
SELECT
`vouchers`.`VoucherID` AS `VoucherID`,
`vouchers`.`VoucherCode` AS `VoucherCode`,
`vouchers`.`Description` AS `Description`,
`vouchers`.`StartDate` AS `StartDate`,
`vouchers`.`EndDate` AS `EndDate`,
`vouchers`.`Discount` AS `Discount`,
`vouchers`.`VoucherTypeID` AS `VoucherTypeID`,
`vouchers`.`catalogueID` AS `catalogueID`,
`vouchers`.`catItemId` AS `catItemId`
FROM `vouchers`
WHERE (((TO_DAYS(CURDATE()) - TO_DAYS(`vouchers`.`StartDate`)) >= 0)
AND ((TO_DAYS(CURDATE()) - TO_DAYS(`vouchers`.`EndDate`)) <= 0));
I need more specifics on how to reproduce the error in order to troubleshoot.
