Why does DataAssit crash so often
Thread begun 3/09/2015 11:10 am by Solis Web Design And Hosting | Last modified 3/16/2015 9:54 am by Jason Byrnes | 6176 views | 14 replies |
We have done all the suggested things....remove cache file and reboot...re-install the actual pogram...disable preview so program doesn't have to preview page and it still crashes at least once when using it...
This has been an ongoing issue witth this program..
Can't these types of issues be fixed?
I'm sure i'm not the only one this program is crash friendly and it's really frustrating considering if this program did not crash it would be so great
We believe we have identified the cause of the crashing and are planning to have an update to Data Bridge available this week that we hope will fix the issue.
I will update this thread when the update becomes available.
that would be great i can't wait...thank you
An update to Data Bridge 1.2.2 was released yesterday that should fix the crashing issue.
Make use to uninstall the previous version from the extension manager before installing the update.
as far as the crashes those are resolved but i'm getting this error when i launch the program...view image
I have tried all the common install issues like removing cache file as well as uninstalling and re installing and this error still comes up...please heelp
Ray has done a hot fix build for this issue.
uninstall DB 122 then reinstall it, m,make sure the web assist installer runs when you start Dreamweaver and that should install the fix.
I uninstalled it from the extension manager....then re installed it and then launched DW which it went through the three steps which it then said to restart DW...
Did that and just to make sure i reset my work space and removed the cache file and still the same error
Vlad
just copy from my topic, after reinstallation:
And again!!!!
ok, guys!!!!
or You found the way for make Your product start work, or I make this video + some screenshot public on Youtube with many useful tags
Kind regards
Vlad
I don't believe!!!
Ok, we where able to reproduce the error. and have done another hot fix for it last night.
try recreating the users configuration folder, then open DW to recreate it.
Close DW and open the extension manager, remove the extensions then reinstall them to install the latest updates.
