cc email based on checkbox
Thread begun 3/08/2015 3:23 pm by asnw0764437428 | Last modified 3/09/2015 11:40 am by Jason Byrnes | 3391 views | 7 replies |
asnw0764437428
The set up works as follows.
A user clicks on a banner that calls up specific details from a database and appends those details to a form (hidden) with additional fields for their name, email address to enter etc. etc.
At the bottom of the form is a checkbox which is binded with the email address thats pulled from the database.
The option is, if this checkbox is clicked the email address binded to the checkbox also receives a copy of the whole form including the appended details that were pulled from the database when submitted.
This final part is not working as for some reason regardless of whether the checkbox is checked a copy is still sent to that specific email address.
Any suggestions on how to fix this?
I've attached a stripped out page with current code minus the design etc.
when you test what email address is in the value of the checkbox?
and please send a copy of the webassist/email/waue_apply_1.php file so i can see the code for the email settings.
asnw0764437428
The email address for the checkbox value is dynamic as its pulled from the database and dependant on which banner is clicked in the first place. This all works ok. The problem seems to be with the checkbox itself. It sends a copy of the completed form regardless of whether the checkbox is ticked or not.
waue_apply_1.php attached
asnw0764437428
see pm
so, the version of the apply.php page on your server is not the same as the one you sent me in your massage.
on the server, you are creating an array of the ccmail elements, one as a hidden element:
<input type="hidden" name="ccmail[]" value="<?php echo $row_pulllinkIn['bis_email']; ?>" id="ccmail_0" />
and then one as the checkbox.
<input type="checkbox" name="ccmail[]" value="" id="ccmail_1" />
the checkbox doesn't have a value, so it won't do anything. but the hidden element always a value.
the email is being sent the cc address because of the hidden element.
on your page i deleted the hidden element and edited the checkbox:
<input type="checkbox" name="ccmail" value="<?php echo $row_pulllinkIn['bis_email']; ?>" id="ccmail_1" />
i also had to remove the implode functions in the webassist/email/waue_apply_1.php file.
asnw0764437428
pm
you're welcome.
