Can mySqli be used with server validation?
Thread begun 3/06/2015 4:00 pm by danny405167 | Last modified 3/09/2015 9:28 am by Jason Byrnes | 1092 views | 1 replies |
danny405167
If it can, then you can you please tell me how to correctly write the variable that used to be $totalRows_RecordsetName? I tried using $rsVerifyID but I got the following error
Catchable fatal error: Object of class WA_MySQLi_RS could not be converted to string in E:\vhosts\dev-3\plugins\login\plugin_registration.php on line 36.
line 36: $WAFV_Errors .= WAValidateNM($rsVerifyID . "",1,1000,"",",.",true,2);
$rsVerifyID is the recordset object.
you will need to tell it to use the TotalRows item of the recordset object:
$rsVerifyID->TotalRows
$WAFV_Errors .= WAValidateNM($rsVerifyID->TotalRows . "",1,1000,"",",.",true,2);
