i can't use the product it won't install
Thread begun 3/06/2015 10:32 am by rickoneil | Last modified 3/10/2015 10:24 am by Jason Byrnes | 4173 views | 7 replies |
rickoneil
getting this error
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\Inetpub\vhosts\134severin.com\httpdocs\install_cms\database.php:9) in C:\Inetpub\vhosts\134severin.com\httpdocs\install_cms\global.php on line 3
Warning: Cannot modify header information - headers already sent by (output started at C:\Inetpub\vhosts\134severin.com\httpdocs\install_cms\database.php:9) in C:\Inetpub\vhosts\134severin.com\httpdocs\install_cms\wizard.php on line 87
rickoneil
private reply
see private
See PM
rickoneil
see pm
pm
all of the files in the install_cms folder had become corrupted, on uploading them, the code became double spaced which caused the error. see the attached screen shot to see what I mean.
I uploaded a fresh copy of the install_cms folder to correct the problem.
rickoneil
install completed then this
see pm
"OK Close this ticket, I'm moving the site to a different server. i think all the files are uploaded as corrupt starting over on new server"
try using File Zilla or another 3rd part FTP Program to upload the files to the server. By Default Dreamweaver uses the ASCII File transfer mode which can sometimes cause it tot upload everything and convert to double spacing. you may be able to edit the DW Transfer mode settings, see this thread:
http://www.webassist.com/forums/posts.php?pid=168960
