CSS Menu Writer Edit Theme Window Too Big
Thread begun 8/28/2009 9:49 am by Wayne366927 | Last modified 2/23/2010 1:11 pm by Jason Byrnes | 4669 views | 6 replies |
Wayne366927
Hello:
When I open CSS Menu Writer Edit Theme Window it is so large that the Save button is below the fold on my screen, so I cannot save any changes. I cannot move the window up far enough to get to the Save button. I also cannot resize the Edit screen to make the Save button accessable. Any advice appreciated.
What is your screen resolution?
try changing the resolution to something like 1024 x 768
Wayne366927
Hi Jason:
It is set to 1024 x 768. I have tried changing up and down in size. No change. It opens prportional to the screen. I have CS4 and Windows Vista. Super Suite with Menu Writer 2.0.2.
What is the screen DPI Setting? Make sure it is set to 96. I found this tutorial on the web for changing the DPI in Windows XP:
change_dpi_settings_xp.htm
Jenny I
Hi
I seem to be having the exact same problem. I have tried all the suggestions but still cannot get the window to resize.
Any Updates?
Jenny I
Ok I have just taken my resolution up to 1440 x 900 and it has worked. I am just wondering why I have had to to this as I have never had a problem with any of the other Web Assist products at my preferred (lower) resolution.
The edit theme window is set to be 760 x 765, your screen resolution must be set to accommodate for those dimensions, the actual rendered size of the UI will include about 20 pixels in padding.
