Workspace deleted cache deleted still getting mysqli javascript errors
Thread begun 3/05/2015 4:34 pm by Warrio | Last modified 1/14/2016 2:26 pm by Ray Borduin | 3843 views | 8 replies |
Warrio
I'v done all the recommended of resetting the workspace and deleting the cache file, but when I try and create a mysqli recordset I get a javascript error
It's an active document, that I've gone back to edit
SOLVED?
I deleted the eCart object and applied it again, after that I could use the mySqli Server behaviour again
Cheers
Norman
Nick Green
I am getting the same problem, but I haven't got eCart installed. Just run the deprecated panel and Webassist's MySQLi extension. Any ideas anyone? I have deleted the .dat file and reset workspaces.
What is the exact error?
Nick Green
I'm getting this: "While executing applyServerBehavior in dynamicSelectList.htm, a javascript error occurred".
This is related to trying to apply a dynamic select for a RS of products.
Do you have a copy of the page I can look at with the select list?
Nick Green
Hi Ray,
Apologies, I have just solved the issue. For reference here is what I think the problem was:
I had an existing dynamic <option> in the select. In the past (and before using the Webassist function) I have been able to apply a repeat region to the <select> and then do the dynamic "if selected" function. However using the Webassist function to perform the same approach seemed to cause the issue.
By removing out the entire repeat region around the <option> and then using the Webassist function I was able to get this working. It seems that the Webassist function gets confused if something is there already ;-)
Cheers
Nick
I'll look into the issue with existing options to see if we can get it fixed in the next update. Feel free to give me a call to discuss any other issues or questions you might have. Our office number is located at the bottom of every page.
Nick Green
Perfect, thanks Ray.
Please post your skype contact information in the private area if you would like to schedule a premier support ticket
