SSL Symbol not clearing in Firefox
Thread begun 3/05/2015 9:31 am by johna1964 | Last modified 3/06/2015 8:44 am by Jason Byrnes | 6017 views | 19 replies |
johna1964
Hi! I noticed this issue about a week or so ago and contacting the hosting provider. They could not reproduce this issue; however, it is an ongoing issue in more than one location from my end. It is not an image issue. The only thing I could think of is perhaps the htaccess file. Webassist helped with editing this file and it worked as it should up to this point. I am uploading both htaccess files; one for before WA assistance and the one WA edited. I would like to know if you see anything that could be the cause for this.
You can go to the log in page to see if you have the same Firefox warning symbol: https://www.ecigaretteimpressions.com/accountaccess/login.php
I have uploaded both htaccess files although they aren't neat and tidy as on the server.
Thank you so much for your help!
looking at the source of your p[age, i can see a number of links that use HTTP addresses:
<div><a href="http://www.casaa.org/Electronic_Cigarettes.html" target="_blank" style="color:#FFF"><img src="../images/template_images/casaa-graphic.gif" border="0" width="66" height="65" alt="Link to Cassa" longdesc="../images/template_images/casaa-graphic.gif" /></a><br />
<span style="color:#FFF; font-size:12px">Support CASAA</span></div>
<p class="column"><span style="color:#F0F">Additional Resources:</span><br />
<a href="http://www.e-smokers-forum.com/" title="Link to E-Smokers-Forum" target="_blank" style="color:#FFF">ESF</a><br />
<a href="../why_do_people_smoke.php" title="Link to Article" style="color:#FFF">Healing Lungs</a><br />
<a href="http://en.wikipedia.org/wiki/Vegetable_Glycerine" title="Link to Wikipedia VG Info" target="_blank" style="color:#FFF">VG</a><br />
<a href="http://en.wikipedia.org/wiki/Propolene_glycol" title="Link to Wikipedia PG Info" target="_blank" style="color:#FFF">PG</a><br />
</p>
these can cause the type of issue you report.
johna1964
Thank you for the quick response :-)
I took the code out. I actually did that yesterday too. I just did it again, then uploaded only the login page. No change. It is continuing to show the firefox caution symbol. Any other ideas?
Thank you again!
there are other lines using http addresses as well.
johna1964
I can see that.
What about these then:
Ok, I have tested on phone; Laptop; Desktop... so far the issue is found only using a desktop. I asked my brother to test from his desktop in firefox. He is unable to open in Firefox... so I'm thinking this may be a hosting provider issue.
I'll update when I figure it out.
Thank you again, Jason!
johna1964
Hi again!
Okay, the only solution is to force ssl for the entire site. This may work; however, the hosts code is the following:RewriteEngine On
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://example.com/$1 [R=301,L]
This is the code that was on the original htaccess file before WA assistance.
How would I make this happen without disturbing the WA code?
Thank you again!!
change:
# Redirect non-www urls to www
RewriteEngine on
RewriteCond %{HTTP_HOST} !^www\.ecigaretteimpressions\.com
RewriteRule (.*) http://www.ecigaretteimpressions.com/$1 [R=301,L]
RewriteEngine on
but I don't think thats the problem.
I think it is a problem with the some of the script files calling outside resources using http
for example:
options.enableSearchboxOnly("http://www.ecigaretteimpressions.com/search_and_results_new.php");
or:
onclick="window.open('http://reddit.com/submit?url=https%3A%2F%2Fecigaretteimpressions.com%2Findex.php')">
and there are others.
in your source, there is also this link:
<link rel="stylesheet" type="text/css" href="webassist/social/wasocial.css"/>
which goes to a 404 error page, the 404 error page uses standard http resources also, that could be causing the issue.
it's also possible that your SSL Certificate does not set the ownership information
http://www.cknow.com/cms/articles/why-do-i-see-this-web-site-does-not-supply-ownership-information-in-my-browser.html
not all SSL Certificates supply that information.
johna1964
Please see private
