help with a mySQLi recordset
Thread begun 3/02/2015 11:10 am by Christopher West | Last modified 3/02/2015 12:59 pm by Jason Byrnes | 4490 views | 6 replies |
Hello there, I have a MySQLi recordset that takes in 2 URL parameters:
?Department=&Category=
And I have a dropdown menu, so for example the Menu item 'Living' would be department and it would contain many categories. So that all works fine...however lets say on my homepage I have a info-graphic link for 'Living' so if the user clicks on that it will take them to the page that will display ALL categories items. How can i do this?
The example URL would be:
category.php?Department=Living&Category=Occasional-Chairs
But lets say I have an infor-graphic link that directs to:
My recordset is:
if(true){
    switch(isset(
$_GET['Department'])?$_GET['Department']:""){
        case
"New-Arrivals":
$rsProducts = new WA_MySQLi_RS("rsProducts",$ecartdb,0);
$rsProducts->setQuery("SELECT * FROM products WHERE ProductNewArrival = 1");
$rsProducts->execute();
        break;
        case
"Best-Sellers":
$rsProducts->setQuery("SELECT * FROM products WHERE ProductBestSeller = 1");
        break;
        case
"InStore-Now":
$rsProducts->setQuery("SELECT * FROM products WHERE ProductInStoreNow = 1");
        break;
        case
"Search":
$rsProducts->setQuery("SELECT * FROM products");
            if (isset(
$_GET["Price"])) {
$prices = explode(":",$_GET["Price"]);
$rsProducts->addFilter("ProductPrice",">=","d",$prices[0]);
$rsProducts->addFilter("ProductPrice","<=","d",$prices[1]);
$productTypes = array();
                if (isset(
$_GET["Wood"])) {
$productTypes[] = "Wood";
                if (isset(
$_GET["Metal"])) {
$productTypes[] = "Metal";
                if (isset(
$_GET["Glass"])) {
$productTypes[] = "Glass";
                if (
sizeof($productTypes) > 0) $rsProducts->addFilter("ProductType","=","s",$productTypes);
                if (isset(
$_GET["Product"])) {
$productName = $_GET["Product"];
$splitName = explode(" ",$productName);
                    for (
$x=0; $x<sizeof($splitName); $x++) {
$splitName[$x] = "%" . $splitName[$x]."%";
$rsProducts->addFilter("ProductKeywords","LIKE","s",$splitName);
$rsProducts->setFilter();
        break;
        default:
$rsProducts->setQuery("SELECT products.*, categories.* FROM products INNER JOIN categories ON products.ProductCategoryID = categories.CategoryID WHERE categories.CategoryLink = ? AND categories.CategoryLocation = ?");
$rsProducts->bindParam("s", "".(isset($_GET['Category'])?$_GET['Category']:"")  ."", "-1"); //WAQB_Param1
$rsProducts->bindParam("s", "".(isset($_GET['Department'])?$_GET['Department']:"")  ."", "-1"); //WAQB_Param2
        break;
Regards
Chris
so this is working on the default recordset.
it sounds like you want to make the categories.CategoryLink part of the where clause:
WHERE categories.CategoryLink = WAQB_Param1 AND categories.CategoryLocation = WAQB_Param2
be optional
so change the where clause to:
WHERE (categories.CategoryLink = WAQB_Param1 OR -1 = WAQB_Param3) AND categories.CategoryLocation = WAQB_Param2
the create the variable as:
Type: Text
Default Value: -1
Runtime Value: $_GET['Category']
Type: Text
Default Value: -1
Runtime Value: $_GET['Department']
Type: Text
Default Value: -1
Hi Jason, Do you mean the recordset would be the below (currently it doesnt work)
default:
$rsProducts->setQuery("SELECT products.*, categories.* FROM products INNER JOIN categories ON products.ProductCategoryID = categories.CategoryID WHERE (categories.CategoryLink = ? OR -1 = ?) AND categories.CategoryLocation = ?");
$rsProducts->bindParam("s", "".(isset($_GET['Category'])?$_GET['Category']:"")  ."", "-1"); //WAQB_Param3
break;
looking at the logic of the recordset...shouldnt this work:
            $rsProducts->setQuery("SELECT products.*, categories.* FROM products INNER JOIN categories ON products.ProductCategoryID = categories.CategoryID WHERE ((categories.CategoryLocation = ? AND categories.CategoryLink = ?) OR categories.CategoryLocation = ?)");
            $rsProducts->bindParam("s", "".(isset($_GET['Department'])?$_GET['Department']:"")  ."", "-1"); //WAQB_Param1
            $rsProducts->bindParam("s", "".(isset($_GET['Category'])?$_GET['Category']:"")  ."", "-1"); //WAQB_Param2
            $rsProducts->bindParam("s", "".(isset($_GET['Department'])?$_GET['Department']:"")  ."", "-1"); //WAQB_Param3
at the moment its returning ALL records for any of the categories in 'Living'
Chris
the parameters are reversed.
try:
default:
break;
Well thats solved it! Not sure if you saw my second edit of my post before you submitted yours. I changed around a few parameters that logicall would make more sense as 'department' should go first as it contains many 'categories' so I had to them reorder the parameters 1, 2, and 3. But of course that didnt work.
To be honest I was a little puzzled by your code "categories.CategoryLink = ? OR -1 = ?" I didnt think you could put -1 for the URL parameters markup.
Chris
you wouldn't put -1 in the URL variable.
what this is doing is:
if the URL is:
category.php?Category=
the where clause becomes:
categories.CategoryLink = -1 OR -1 = -1
so: OR -1 = -1 evaluates to true
but if you pass a value for the category:
category.php?Category=Occasional-Chairs
then the comparison is:
categories.CategoryLink = Occasional-Chairs OR -1 = Occasional-Chairs
hopefully that clarifies.
Yes perfectly makes sense now (apart from the few syntax errors in the URL examples you gave (sorry had to point out) ;-)
Thanks Jason
