Help With Populating List on Page Load Update Page
Thread begun 3/01/2015 3:44 am by sfranzken73972 | Last modified 3/17/2015 11:22 am by Jason Byrnes | 7871 views | 24 replies |
sfranzken73972
I put this on my onload in the body after following your tutorial but it does not work.
What did I miss?
onLoad="WA_FilterAndPopulateSubList(rssubCats_WAJA,MM_findObj('CategoryID'),MM_findObj('SubCatID'),0,0,false,': ')"
you need a set selected in list behavior was well to set the selected item in the parent list.
sfranzken73972
Follow Up
Do I set that to the sub category drop down?
you need to set it up for the parent list, looks like the parent list is the CategoryID
sfranzken73972
Parent List Follow Up
So I need to remove the array from the parent list first?
Or just have both?
have both.
sfranzken73972
Not working
see attached
there are no unload attributes for the body tag:
<body >
you need to add the set selected in list behavior and the Populate list from array behaviors to the body tag.
sfranzken73972
Still having issue
Not sure I understand Jason what to do, can we discuss via a private meeting?
in the Dreamweaver tag selector, select the body tag.
in the behaviors panel, apply the Set Selected In List behavior to set the selected item in the parent list to the onload attribute of the body tag,
Then add the Populate list from array behavior to populate the child list, also to the onload attribute of the body tag
then add a second set selected in list behavior to set the selected item in the child list. again, this is applied to the unload attribute of the body tag.
