I just want to create a simple form and send its contents
Thread begun 2/25/2015 10:10 pm by david323147 | Last modified 2/26/2015 10:04 am by Jason Byrnes | 3476 views | 7 replies |
david323147
Is there a tutorial on the site to create a a simple form (name, address, phone, email,) and email the contents?
I tried using the wizard (Webassiste>Forms>Insert New Form, with no success. On the form function tab I did check the checkbox for send contents to an email address and in the from field I clicked the lightening bolt and selected Email_Address under Current working form. In the To field I put the email address I want the data sent.
When I test it, the form appears to be submitted, but the email with the information is never received. I do not have this information going to a database. I simply want the form to gather information and email it.
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
NOTE: to edit email settings, open the server behaviors panel, and double click the Universal Email server behavior.
Also, make sure you are testing on the remote server, sending email will not work on a local testing server if no SMTP server is configured.
david323147
Thanks Jason.
I searched my host's (Newtek) knowledge base and found what is below. Unfortunately, I don't know what to do with this information.
Also, how do I set it so the user is automatically redirected to a "success" page?
Your help is greatly appreciated!
Here is an example script for sending out mail using php:
// Please specify your Mail Server - Example: mail.yourdomain.com.
ini_set("SMTP","mail.YourDomain.com");
// Please specify an SMTP Number 25 and 8889 are valid SMTP Ports.
ini_set("smtp_port","25");
// Please specify the return address to use
ini_set('sendmail_from', 'ValidEmailAccount@YourDomain.com');
// Set parameters of the email
$to = "someone@example.com";
$subject = "Test mail";
$message = "Hello! This is a simple email message.";
$from = "someonelse@example.com";
$headers = "From: $from";
// Mail function that sends the email.
mail($to,$subject,$message,$headers);
so this means you need to specify the SMTP server as:
mail.YourDomain.com
where YourDomain is your domain
and set the port to 25.
edit the universal email server behavior, and click the folder icon to access the SMTP server settings.
david323147
Sorry for being so dense about this but I just don't follow.
The attachment below shows my server behaviors window in Dreamweaver. What do I select? I don't see anything having to do with SMTP settings. If I click the + sign and select Edit Server Behaviors I get what you see in the second image but still no SMTP settings.
Thanks for your patience.
in the server behaviors list, double click the Universal Email server behavior to edit it.
in the UE server behavior, click the envelope icon to access the SMTP server settings.
david323147
Ah, got it! And I saw the Go to Page option which I set and all is working.
Again, thank you so much!
you're welcome.
