Access to 'simple' rs query panel
Thread begun 2/25/2015 10:30 am by dylan399236 | Last modified 2/26/2015 7:50 am by Jason Byrnes | 3134 views | 5 replies |
dylan399236
Hi
Recently bought your MySQLi SB and am getting on ok with it.
When creating new MySQLi recordset I get the Advanced dialogue box and when I click the 'Simple' button I get a popup with "The simple Recordset dialog box cannot be opened because the SQL is too complex".
I get this even with a brand new empty page. Any ideas what's happened as when I first installed i had access to both.
Cheers,
Dylan.
that error will happen if the recordset contains multiple where clauses or other SQL that is not available to the Simple Dialog box.
What is the SQL of the recordset?
dylan399236
Thanks for the quick reply Jason
I get this if I create a brand new page and go straight to Webassist>MySQLi>MySQLi Recordset.
The Recordset dialogue box opens in advanced mode and pressing the 'Simple' button gives the error/warning - even before I've added any SQL query (screenshot attached).
I realise that once adding a more complex query that I can't go back to the simple dialogue box.
Cheers,
Dylan.
Strange. I'm not able to reproduce, but try this:
Open the Standard DW Recordset dialog box, it too should open in advanced mode. Change it to Simple then click cancel.
On opening the Standard RS Dialog again, it should now default to simple mode. hit cancel again, and then try opening the MySQLi recordset dialog, it should now be set to default to simple mode.
dylan399236
The irony. I bought this extension so I wouldn't (shouldn't) use the standard DW or ADDT panels any more :)
Thanks Jason that seems to have sorted things out and I can see the basic WA RS panel again.
Much appreciated,
Dylan.
you're welcome.
