Authenticating with encrypted password
Thread begun 2/23/2015 4:55 pm by kelly1398725 | Last modified 7/12/2021 11:04 pm by Rokon | 6489 views | 16 replies |
kelly1398725
I am using the log in user to authenticate users comparing username with password.
Password is encrypted with SHA1. How can I use log in user to verify the user's password by encrypting it again and comparing the two encrypted versions.
Thank you for any pointers.
in the login behavior, when you select the password for element, the code for the value will look like:
<?php echo ((isset($_POST["password2"]))?$_POST["password2"]:""); ?>
edit that code to add the sha1() function:
<?php echo ((isset($_POST["password2"]))?sha1($_POST["password2"]):""); ?>
kelly1398725
Thanks Jason. Very useful extension. Simple and clean codes.
you're welcome.
davidtricker376400
I'm confused, I'm trying to use the password_verify() function in PHP. When I add it to the line
$Authenticate->addFilter("password", "=", "s", "".((isset($_POST["password"]))?password_verify($_POST["password"]):"") ."");
at the top of my login page it doesn't allow anyone to login.
Where would I need to add <?php echo ((isset($_POST["password2"]))?password_verify($_POST["password2"]):""); ?> as in your example to get this to work?
My passwords are being stored successfully using
$spw = ((isset($_POST["password"]))?$_POST["password"]:"");
$storePW = password_hash($spw, PASSWORD_BCRYPT, array('cost' => 10));
I'm just having difficulty authenticating them.
I think you would use:
<?php echo ((isset($_POST["password2"]))?password_hash($_POST["password2"], PASSWORD_BCRYPT, array('cost' => 10)):""); ?>
davidtricker376400
Thanks Ray but that doesn't work. I've added several users to the test database with the same password and they are all stored differently in the database, this makes me think a different salt is being used every time, so this would return false as the password hashes would be different. Looking at the interweb there is a process for checking the hashed password against the form input using password_verify().
That would entail pulling the password from the db using the username and storing it in a string and then comparing it to the input password e.g.
$storedpassword = "some value from database";
$inputpassword = ((isset($_POST["password"]))?$_POST["password"]:"") ;
if (password_verify($inputpassword, $storedpassword) {
code if valid
} else {
code if not valid
I've tried to integrate this into the $authenticate function from webassist, but I keep on breaking it. Any help would be appreciated.
Thanks.
You could use that code to set a session variable and then use the session variable as the trigger for the MySQLi authenticate.
So:
1) Create a recordset filtered by the entered email address
2) Then use your code to validate the password returned with this code:
$storedpassword = $yourRecordset->getColumnVal('paswordColumn');
@session_start();
if (password_verify($inputpassword, $storedpassword)) {
$_SESSION['auth_trigger'] = "passed";
} else {
$_SESSION['auth_trigger'] = "";
3) then set your MySQLi login trigger to: $_SESSION['auth_trigger'], only use the email address for the login filter.
davidtricker376400
Thanks Ray, that has been most useful, so just to be clear, this:
if (isset($_POST["submit"]) || isset($_POST["submit_x"])) {
$Authenticate = new WA_MySQLi_Auth($db);
$Authenticate->Action = "authenticate";
$Authenticate->Name = "Login";
$Authenticate->Table = "admins";
$Authenticate->addFilter("username", "=", "s", "".((isset($_POST["username"]))?$_POST["username"]:"") ."");
$Authenticate->addFilter("password", "=", "s", "".((isset($_POST["password"]))?$_POST["password"]:"") ."");
$Authenticate->storeResult("username", "userName");
$Authenticate->storeResult("superuser", "superUser");
$Authenticate->AutoReturn = false;
$SuccessRedirect = "/success/";
$FailedRedirect = "/failed/";
if (function_exists("rel2abs")) $SuccessRedirect = $SuccessRedirect?rel2abs($SuccessRedirect,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$Authenticate->SuccessRedirect = $SuccessRedirect;
$Authenticate->FailRedirect = $FailedRedirect;
$Authenticate->execute();
would then become:
if (isset($_SESSION['auth_trigger']) && ($_SESSION['auth_trigger'] = "passed")) {
Hopefully this will help some others in adding hashed and salted passwords to webassist's login functionality.
Yes I think that would do the trick... remove the blank line or it might not be picked up by the server behavior inspector.
