PowerCMS quit working
Thread begun 2/21/2015 10:44 am by jo271221 | Last modified 2/24/2015 6:48 am by Jason Byrnes | 1759 views | 3 replies |
jo271221
I need to upgrade a store and move it to another server. When I went to test the site that powercms was not working. I got a blank page.
1. What procedure is best to move to new server?
Attempt to fix issues on existing server
Move site to new server, then upgrade, then test
or ? Details attached.
Thank You,
It's best not to move from one server to another, but rather do a fresh installation.
you can then export the products and CMS tables from the old server using phpMyAdmin, then import that data to the new server.
you say:
"1. What procedure is best to move to new server?
or ?"
if there are issues on the old server, it is no good to move to a new server without first fixing them, don't move a broken site, you'll just end up having to troubleshoot on the new server.
if you must troubleshoot the on the new server, a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
jo271221
PowerCMS
Thank you, i have added addtl info. and my mistake. This site is PowerCMS not PowerStore.
"This site has the old CMS without the live editor. So do I just transfer the site as is and then upgrade?"
Yes, you could do that.
