Email Form not Sending Emails Again
Thread begun 2/21/2015 7:39 am by salaroche | Last modified 2/26/2015 8:01 am by Jason Byrnes | 2429 views | 5 replies |
salaroche
Hi:
This issue was supposed to have been solved before, but for unknown reasons the email form simply stopped sending emails. Maybe some code got corrupted or something. I’ve looked up and down the page but I have been unable to detect anything wrong.
Website: www.amarapura.salaroche.com>ContactUs
Any suggestions on this?
Attached please find a copy of the page in question.
Thank you for your attention.
on the success page, i added the following code to write the session contents:
<pre><?php session_start(); var_dump($_SESSION); ?></pre>
in the session, it contains the status of passing the email to the SMTP server, the status returned success:
["waue_Contact_2_Log"]=>
string(98) "Sending To: salaroche@gmail.com... Success
this means the email is being passed to the SMTP server, but the SMTP server is refusing to relay the email for some reason. you will need to contact the host for help in determining why the SMTP server is not relaying the email.
salaroche
Jason:
Thank you for your reply. Before consulting with my Hosting service I sent a couple of emails to myself using the form in question and it worked. I got both emails in my inbox. Could the test you performed have solved the SMTP server issue? It seems that it did.
No, I didn't change any code on the pages.
salaroche
OK. Then it was probably one of those inexplicable unknown intervention situations. What matters is the email form is working now and it wasn't working before.
Thanks for your attention.
you're welcome.
