Data assist error at line 125 of file
Thread begun 2/20/2015 1:22 pm by john70964 | Last modified 2/23/2015 8:21 am by Jason Byrnes | 1684 views | 3 replies |
john70964
When attempting to create Data Assist pages in the wizard I get the error shown in the attached image.
I have seen this previously.
I tried deleting the config file but it made no difference.
Thanks for any help.
John.
this error happens if you are using one of the presets with your own table and the table columns do not match the preset.
to prevent this from happening, make sure you are using the table the preset was defined for, or you can select to have the table created for you.
john70964
Looking at DataAssist: Create Pages
I have tried with and without presets but still having problems.
I noticed a differnce in what I expected.
I select the table which is productcategories key column CategoryID but on the right side the display shows items from the table products.
The same is true for the Manage Pages tab.
Is this correct?
I am attaching 2 images.
John
you need to go to the manage pages tab and edit each of the page to select the columns from the product categories table that will be used.
