line break <br> appearing in unordered list in email?
Thread begun 2/20/2015 2:30 am by Mags | Last modified 2/20/2015 11:12 am by Jason Byrnes | 2952 views | 5 replies |
Mags
I have a Universal Email behavior using a standard template. There's an unordered list in the email is formatted as follows:
<ul>
<li>Item 1</li>
<li>Item 2</li>
<li>Item 3</li>
</ul>
However when the email is sent, an extra break is appearing after the bullet point. I copied the source code from the email that arrived and it looks like this:
<ul>
<li><br>Item 1</li>
<li><br>Item 2</li>
<li><br>Item 3</li>
</ul>
resulting in a very messy looking list! Any idea how I can prevent this?
Mags
Hi Jason
See PM.
on viewing source in the HTML Editor window, the code for the list is:
<ul>
<li>
The aeMadeeasy system is suitable for employers of any size.</li>
<li>
It is exclusively available through Peak accountancy firms and has been developed in conjunction with Jargonfree Benefits™.</li>
<li>
aeMadeeasy manages and runs the process of auto-enrolment, employee communications and the required record keeping for employers.</li>
<li>
It is a cloud-based system that does not need to be installed locally.</li>
</ul>
with a line break after the <li> tags.
in the webassist/email/temaplates/Blank_6.php file that is the email body for this page, there is the following code to add the HTML Editor into the email body:
<td style="padding: 3px;"><?php echo(str_replace("\n","<BR />",(is_array($pval)?implode(", ",$pval):$pval))); ?></td>
this is converting new lines to <br> tags.
i removed the str_replace:
<td style="padding: 3px;"><?php echo((is_array($pval)?implode(", ",$pval):$pval)); ?></td>
to prevent the <br> tags being added to the list.
Mags
That's fixed it, thanks - I had to add in a bottom margin to the <p> style as well as it removed all the spacing between paragraphs, but working fine now!
you're welcome.
