Mysqli Recordset search Like Session not working
Thread begun 2/19/2015 10:56 am by hbibizadeh396670 | Last modified 2/20/2015 8:38 am by Jason Byrnes | 6498 views | 9 replies |
hbibizadeh396670
I have created a Hashtag system and need to search based on a url par
my url looks like this:
untitled4.php?SearchTag=#great
I have created this code to create the session and remove the # from the par
if(isset($_GET['SearchTag'])) {
$SearchTerm = $_GET['SearchTag'];
$SearchTerm = preg_replace("#[^0-9a-z]#i","",$SearchTerm);
I now have the mysqli recordset searching based on the var
<?php require_once('Connections/Connections.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
$Search = new WA_MySQLi_RS("Search",$Connections,1);
$Search->setQuery("SELECT * FROM siteezy_posts WHERE Post = ?");
$Search->bindParam("s", "".(isset($_SESSION['SearchTerm'])?$_SESSION['SearchTerm']:"") ."", "-1"); //colname
$Search->execute();
for some reason it is not working and i only get a blank page?
Thanks in advance
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
one obvious issue i see is that you are trying to use a session variable in the recordset, but i don't see where the session is being created.
hbibizadeh396670
Thank you for your reply.
Here is the updated first part of the code
$_SESSION["$SearchTerm"] = $_GET['SearchTag'];
$_SESSION["$SearchTerm"] = preg_replace("#[^0-9a-z]#i","",$SearchTerm);
I am getting these errors
Notice: Undefined variable: SearchTerm in C:\wamp\www\siteroot111\untitled4.php on line 7
Notice: Undefined variable: SearchTerm in C:\wamp\www\siteroot111\untitled4.php on line 8
thanks again :)
this code:
doesn't look right. you can't use a variable in the session name.
try:
$_SESSION["SearchTerm"] = $_GET['SearchTag'];
$_SESSION["SearchTerm"] = preg_replace("#[^0-9a-z]#i","",$_SESSION["SearchTerm"]);
when reporting an error, I need a copy of the page so i can see what the code in the error is.
hbibizadeh396670
Ok I am getting results however it is not returning records that contain the value of the session
the results only return if the field contains nothing but the value of the session
In the SQL I changed the = to LIKE but it did not work
Here is the code
session_start();
$Search = new WA_MySQLi_RS("Search",$Connections,0);
$Search->setQuery("SELECT * FROM siteezy_posts WHERE Post LIKE ?");
$Search->execute();
in the recordset, change the filter type to Contains Text.
currently the data type for the colname variable is set to Text, it needs to be set to Contains Text.
hbibizadeh396670
In the webassist window.. i select filter post -> contains -> my session
But it is still not working
Here is the code
session_start();
$Search->execute();
<!doctype html>
<html>
<head>
<meta charset="utf-8">
</head>
<body>
while(!$Search->atEnd()) {
<?php echo($Search->getColumnVal("Post")); ?>
$Search->moveNext();
$Search->moveFirst(); //return RS to first record
</body>
</html>
this line:
should be:
$Search->bindParam("c", "".(isset($_SESSION['SearchTerm'])?$_SESSION['SearchTerm']:"") ."", "-1"); //colname
hbibizadeh396670
Thank you.. all is working! :)
you're welcome.
