Security access rules.
Thread begun 2/19/2015 6:23 am by bbgd | Last modified 2/19/2015 11:18 am by Jason Byrnes | 4725 views | 9 replies |
bbgd
I would appreciate it if you could check my access rules to make sure i have them where they need to be.
Level 1 (MobileSupport) should only get into mobile_support.php & investors.php
Level 2 (OffGrid) should only get into offGrid.php & investors.php
Level 3 (FracWater) should only get into frac_water_filtering.php & investors.php
Level 4 (MajorClients) should be able to get into any of the 3 levels above.
Level 5 (Exec )should get it not expanded_scenarios.php, contactInfo.php and all pages assigned to levels 4 and below
Level 6 (Admin) should get into everything
I have attached the username and passwords for each in the private attachment
no, that doesn't look right.
your access groups look off.
for eaxmple:
so you are saying that user level 1 and 6 (Admin) should have access to mobile_support.php & investors.php
on those 2 pages you have applied the Exec access rule which is defined as:
Allow if Session Userlevel In Group Exec
The exec group is defined with the following members:
5
now there are 2 problems with this:
- this is not the level you say should get access to these pages, 1 is
- since you want these pages to be accessible to the admin also, the group should include 6
you have an access rule for mobile support, but it is set as:
all if Session user level = 1
you should create a mobile support user group with members 1 and 6 and use that group in the mobile support access rule, and use that access rule on the desired pages.
honestly your access groups look totally off.
the admin access group is defined with members:
1,2,3,4,5,6
that seams of, it should only have one member:
6
which is the admin user level.
bbgd
I'm still confused. What i am putting in the group is the security level of who I want to see that page. If that's so, is the following correct
Level 1 (MobileSupport) 1 & 6 in group
Level 2 (OffGrid) 2 & 6 in group
Level 3 (FracWater) 3 & 6 in group
Level 4 (MajorClients) 1, 2, 3, 5 & 6 in group
Level 5 (Exec ) 4, 5 & 6 in group
Level 6 (Admin) 6, no group
that looks correct.
also, make sure you have the proper access rule applied to the pages, as noted, you had applied the Exec access rule to pages that should be using the Mobile Support rule.
bbgd
I uploaded the new security assist stuff and now I can get into anything without a code. help. There is going to be some real sensitive stuff on here soon.
This is an addition. I just realized I have those empty things again. I will fix, re-upload and see what that does.
each of the access groups has an empty member.
For example, edit the Admin Access Group, and try to select the space under the 6, it allows you to select an empty space, delete that empty member.
same holds true for all access groups except Power Users and Admin and Visitor and Power users and Visitors
bbgd
Okay, I fixed the empty member problem. I deleted the cookies and went back to the page. I logged in the offGrid page which is level 2 and signed in with the code for level 4 which has access to 1, 2, & 3 levels. i then went to the contact info on the contact us. This is designated as Exec or level 5. I was able to get in without the code.
This is where my problem is. I want level 5 to be able to get into levels 1-4, but i don't want levels 1-4 to get into level 5. How do I put that.
I don't quite follow.
looking at the offered page, you have applied the offGrid access rule which is defined as
allow if user lever in group offGrid
offGrid has members defined as:
6,4,2
you can access that page when logged in as level 4 because 4 is a member of the access group that page uses.
"This is where my problem is. I want level 5 to be able to get into levels 1-4, but i don't want levels 1-4 to get into level 5. How do I put that."
it doesn't really work that way.
pages that you want to be accessed by levels 1-5 create a rule with an access group for levels 1-5
pages that level 5 should not be able to access, don't add level 5 to access group.
bbgd
I'm starting to grasp it. I need to add a seperate group for a 1-5 allowance
yes, if there are pages that need 1-5 allowance, you need a group and access rule to define that.
