No such file or directory (2) & Cannot send session cache limiter - headers already sent
Thread begun 2/18/2015 3:48 pm by jwk | Last modified 2/19/2015 8:46 am by Jason Byrnes | 1156 views | 2 replies |
jwk
details.php page
Warning: session_start() [function.session-start]: open(/home/content/85/785/tmp/sess_2k5m7n3j4pjnc5lv9o44ptjpa2, O_RDWR) failed: No such file or directory (2) in /home/content/85/785/html/QAWV/WA_eCart/WA_eCart_Definition_PHP.php on line 465
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/85/2785/html/QAWV/WA_eCart/WA_eCart_Definition_PHP.php:465) in /home/content/85/785/html/QAWV/WA_eCart/WA_eCart_Definition_PHP.php on line 465
/tmp/sess_2k5m7n3j4pjnc5lv9o44ptjpa2, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct () in Unknown on line 0
jwk
Notes
Private
This is a server configuration issue. you will need to contact the host to have them fix this.
This error normally means a bad setting for the session.save_path in the php.ini.
