eCart checkout working on one site but not the other
Thread begun 2/18/2015 12:00 pm by BillHobbs | Last modified 2/19/2015 12:28 pm by Jason Byrnes | 3275 views | 7 replies |
BillHobbs
I have 2 sites PreservingYourHeritage.com and FamilyFriendlyStore.com. I copied the database and all the files from PYH.com to FFS.com. Then I updated the confirm.php file to use the correct url data (instead of https://www.preservingyourheritage.com I changed it to https://www.familyfriendlystore.com) then I updated the Paypal Advanced login information. On the PYH.com the Paypal Advance Credit Card window shows up but on the FamilyFriendlyStore.com the checkout page always defaults to the checkout failure information. It doesn't even try to load the Paypal Advance Credit Card window. Besides the gateways.php and confirm.php is there another page I need to modify. I'm using the same database structure and files.
on the checkout failure page, add the following code to dump the session:
<pre><?php var_dump($_SESSION); ?></pre>
the session will contain the response from the gateway with details on why it is failing.
BillHobbs
It returned NULL
try adding session_start();
<pre><?php session_start(); var_dump($_SESSION); ?></pre>
BillHobbs
This is what it returned.
view source of the page and the response from paypal is:
RESPMSG=User authentication failed"
I see you are using hand coding in the credentials file to pull the info from a database, paypal is not accepting the info you have stored.
BillHobbs
You're right there was a space where there shouldn't have been. It works. Thanks.
you're welcome.
