Cs4
Thread begun 8/28/2009 2:59 am by Remco209061 | Last modified 9/02/2009 12:19 pm by Jason Byrnes | 3505 views | 4 replies |
Remco209061
Cs4
Hi There,
I can't find securityAssist in Dreamweaver CS4 after installing it with the extention manager CS4. I'm using 1.1.7. I restarted Dreamweaver but without results. Also the Cookiestoolkit is gone.?
In CS3 it's working.
In Dreamweaver CS4, go to Commands -> Manage Extensions. Are SecurityAssist and Cookies Toolkit listed in the extesnion manager? Is there a check mark in the enabled column for both of them?
If so, they should be available under the Insert menu: Insert -> WebAssist - Security Assist and Insert -> WebAssist -> Cookies Toolkit.
If you continue to have problems, please post screen shots of the Extension manager and insert menu.
Remco209061
Cs4
Hallo Jason, see the screendump.
I have created a support ticket for you so we can look into the cause of this issue.
To view and update your ticket, please log into your support history:
In trouble shooting this we noticed that different extesnion where enabled / disabled when accessing the extension manager from the Commands -> Manage extensions menu in Dreamweaver versus opening the extension manager from the start menu.
An extension that was enabled using the Commands -> Manage extensions menu in Dreamweaver would show in the toolbar, however an extesnion enabled using the start menu would not.
I recommended always accessing the extesnion manager using the commands menu, And contacting Adobe support to troubleshoot why there where multiple Configuration profiles.
