nested rs not displaying records
Thread begun 2/17/2015 2:38 am by Kumel | Last modified 2/17/2015 11:16 am by Kumel | 926 views | 2 replies |
Kumel
i was referring to http://www.webassist.com/tutorials/Display-nested-recordsets
I was using this to display artist name from another table(artworks)
DB structure attached.
artistname seems to appear but artworks seem to be kinda distorted.
artist name are repeated but not the artworks.
I removed repeat region from artwork & added data assist repeat region but i get an error as attached. applyserverbe... error
At the end artwork repeat is not working for both of the above repeat rules
Double check that the image paths are correct for the artwork.
the ing tags:
<img src="artworks/<?php echo($row_WADAartworks['img']); ?>" alt="alt" class="img-responsive" style="width:100%; max-width:800px;">
may not be pointing to the correct location. double check the page source. to see if the path is correct in the source.
also, you have 4 repeat regions around the content, where you really only need 2.
one to repeat the WADAartworks recordset, and the other to repeat the ArtistName nested recordset
Kumel
i re used all of them. seems to work fine now. i guess too many repeat was used so.
thanks a lot
regards
