New problem with MySQLi
Thread begun 2/16/2015 2:35 pm by malcolm230194 | Last modified 2/17/2015 9:29 am by malcolm230194 | 1970 views | 2 replies |
malcolm230194
While updating checkout to MySQLi I reached a point where I couldn't apply a server behavoiur without the following message.
'While executing applyServerBehaviour in MySQLiRecordset.htm, a Javascript error occurred.'
I've tracked down the source of the problem but need a solution. After wasting several days I've isolated it to eCart.
There's no problem working with MySQLi until eCart behaviours are added to save an order. After that any attempt to edit a MySQLi behaviour brings the following error.
From then on the page is a writeoff. This means there is no chance to change anything or correct even a typo in a recordset name without recreating the enitre page
Please look into this as soon as possible.
Hi, When did you download and install eCart. I am aware that there is a newer version of eCart that was uploaded recently..however it kept the same revision number then the previous. it was more of a hotfix. but always worth trying that. Also have you tried deleting the file WinFileCache-########.dat file this file is located at: (for example on my own machine)...
C:\Users\Christopher West\AppData\Roaming\Adobe\Dreamweaver CC 2014.1\en_US\Configuration
(make you you have selected show all hidden files and folders from control panel if your're using a Windows platform)
Regards
Chris
malcolm230194
MySQLi problem
Yes I deleted and reinstalled both extensions and deleted the cache file.
I now have a working page after starting again and making the eCart server behaviours the last to be added. There is however another problem that I couldn't get round.
I allow users to return from the confirm page to the checkout address page in case they need to correct a mistake in address entry. This return resets the $_SESSION['OrderID'] to 7 on return to the confirm page every time meaning that the checkout success page always points to an invalid record. I got round this by using a different session variable to store an order number to access the record but there is something strange happening with eCart on my system.
Does this make any sense?
Regards
Malcolm
