Advice Please - mail error....Sending To: ... mail() has been disabled for security reasons
Thread begun 2/16/2015 12:19 pm by CraigR | Last modified 2/27/2015 11:21 am by Jason Byrnes | 5609 views | 7 replies |
CraigRBeta Tester
I am just setting up a site, where an email is to be sent if a certain trigger is fired.
I set up the email as usual but nothing is being sent.
So i set up email logging and get the error as shown above.
I contact my hosting provider, as I thought this was strange, as I already have 5 or 6 sites hosted with them, and rely on this service for ecommerce sites created using ecart. - never had the problem before,
As it happens, they have been taken over recently, so I wondered if it was a coincidence.
Anyway after a few messages, I get the following response...
"The more we research this, the more it seems wisest to steer clear of PHP|Mail as cPanel is making it much more difficult to provide a stable environment for this feature, likely due to security concerns. Which is actually fine by me as we have seen a variety of outdated code be hijacked and exploited for this purpose over the past year.. I know this isn't supremely helpful news in the slightest. I know that any changes we make will be all-too-likely overridden by cPanel's update processes as Exim is patched up & adjusted, in future releases. We are now advising users to make use of strict SMTP-authentication plug-ins and applicable code snippets to replace the 'auto-authenticated' passthrough that certain older functions allow.
It's not a real life solution, I am well aware of that. That said, I honestly do think it's the wisest way forward considering the circumstances and please let us know if you have any questions about implementation, we're fully able to help you research this. "
I don't know what to make of this.
I also suspect my other sites may have stopped sending confirmation emails, though this is yet to be confirmed
Grateful for any advice.
the PHP mail() function is a fairly insecure method of sending mail, and it sounds like your host is trying to move away from using it and suggesting you use more secure mailing methods, such as Pear Mail.
In Universal Email, on the SMTP server settings tab, you can select to use mail, or use Pear Mail using SMTP. Double check with the host that they have Pear Mail installed for your site and you can use that. Pears Mail offers more security.
CraigRBeta Tester
Thanks Jason - not something I had noticed before.
I have managed to install and configure PEAR and SMTP on my site, and now have it working.
What I would now like to do is be able to test the same functionality, whilst working on my local test site, so I only need to update the $WA_MailObject Path to go live
I have installed PEAR, Mail and SMTP on my local testing server , and am logging my emails, however I get a send failure every time
My local settings are as below,
$WA_MailObject = WAUE_Definition("C:/Program Files (x86)/PHP/PEAR/","mail.localhost","25","","","false","","","","");
I am using vhosts in apache to give me a virtual domain name. but trying either this or localhost gives me an error
10001 - Failed to connect to mail.localhost:25 [SMTP: Failed to connect socket: php_network_getaddresses: getaddrinfo failed: No such host is known. (code: -1, response: )] - Failure <br>
i checked my php.ini and smtp is localhost and port is 25
(Running Apache on Windows 7 x64)
this means the SMTP server is not configured to listen to the address:
mail.localhost
on port 25
What SMTP Server are you using? double check that it is properly configured.
For myself, i don't bother with setting up an SMTP server, i do my local testing through a remote SMTP server.
you may be able to use your hosts SMTP server, or i like to use my Gmail account
you can send through the gmail server by using the address:
ssl://smtp.gmail.com
on port 465
make sure to enable authentication, and use your gmail account details. you may get an email from google about a 3rd party application using your account and you will need to enable 3rd party applications..
CraigRBeta Tester
Thanks Jason,
I couldn;t get the gmail option to work at first, this appears to be because I need to enable 'Access for less secure apps' - and get all of the appropriate security warnings.
It works with this option enabled, I'm guessing that is something I have to have set and there is no way around it ?
Yes, this is what I meant when mentioning the email for google about 3rd part applications.
No, there is not a way around it.
CraigRBeta Tester
Ok, its doing as it should.
Thanks for your help (ps I also got an email saying this thread had been replied to, which is the first notification in a while) ;-)
you're welcome.
Ray was doing some work on the notification emails yesterday, glad to hear it was coming through for you.
