generate js variable names on the fly
Thread begun 8/28/2009 12:47 am by CraigR | Last modified 9/10/2009 2:27 am by Dave Buchholz | 7192 views | 6 replies |
CraigRBeta Tester
linked to yesterdays post...
showthread.php?t=3625
i have a form with several input fields created from a repeat region, namely price1, price2...etc
the number of fields displayed is dependent on how many sizes are available in the sizes recordset.
i want to apply spry validation to each of the input fields so that only numerical values can be input.
i know how many rows my sized recordset produces, so i can pass this into my js
what i want to do is generate the following on the fly, where * is a row number from the recordset
var sprytextfield* = new Spry.Widget.ValidationTextField("sprytextfield*", "currency", {isRequired:false});
i have the following loop which creates the correct information, but only as text string output, how do i get it to work ??...
var totalsizes = <?php echo "'".$totalRows_rssizes."'"; ?>;//this is the number of rows in the sizes recordset, so this is how many sprytextfields we need
</script>
var i=1;
for (i=1;i<=totalsizes;i++)
document.write("var sprytextfield" + i + " = new Spry.Widget.ValidationTextField('sprytextfield" + i +"', 'currency', {isRequired:false});");
document.write("<br />");
sorry, but my js isn't up to much, grateful for any advice
Dave BuchholzBeta Tester
Craig,
I have combined PHP + JS like this in the past
// <![CDATA[
// jQuery calls start here. No need for $(document).ready() here.
for ($i = 0; $i < ($RepeatSelectionCounter_1 - 1); $i++) {
$("#buyNow_<?php echo $i; ?>").click( function() {
if($(this).is(":checked") ) {
$("#qtyReq_<?php echo $i; ?>").removeAttr("disabled").val(1); // Removed $("#qty_0").val()+1
} else {
$("#qtyReq_<?php echo $i; ?>").attr("disabled", "disabled").val(0);
</script>
Maybe that will help ?
CraigRBeta Tester
Hi Dave, thanks for the reply.
As I mentioned, my js isn't up to much, i'll read through your script and see if i can adapt it for my needs.
Regards
CraigRBeta Tester
still struggling with this
Using php, I can set a js variable ok
var sprytextfieldn = <?php... no problems
now what i can't get my head around is this.
if i have 3 rows in my recordset, how do i create 3 js variables on the fly, so i get
varsprytextfield1 = <?php...
varsprytextfield2 = <?php...
varsprytextfield3 = <?php...
and expand this so it works for n rows ?
Craig,
are your text fields in a recordset repeat region ? If yes then use a counter like I showed in my earlier example
CraigRBeta Tester
Cheers Dave
I can't believe I didn't work it out sooner.
// <![CDATA[
for ($i = 1; $i <=$totalRows_rssizes; $i++) {
var sprytextfield<?php echo $i; ?> = <?php echo "new Spry.Widget.ValidationTextField('sprytextfield".$i."', 'currency', {isRequired:false})" ?>;
</script>
sometimes you can stare at things to long !
glad I could help
