map is partially drawn in modal window, info window is blank
Thread begun 2/12/2015 6:23 am by CraigR | Last modified 2/17/2015 9:09 am by Jason Byrnes | 3554 views | 7 replies |
CraigRBeta Tester
Debugger points to a warning on this line...
xmlDoc.open("GET", "webassist/_promaps_cache/_promaps_geocache.xml", false);
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience
LINK
http://test3.forthwebsolutions.com. click on Find Us
try adding an o'clock event to the Find Us link:
onClick="window.setTimeout('google.maps.event.trigger(map1,\'resize\');wagmp_map_1_obj.obj.setCenter(wagmp_map_1_obj.points[0])',30);"
CraigRBeta Tester
no luck with that i'm afraid, result is the same
CraigRBeta Tester
PM
i added the code to recenter the map to the code for opening the modal window to to fix the issue:
$('#findModal').on('shown.bs.modal', function () {
api.rasPause(),
CraigRBeta Tester
Thanks Jason, that puts the map nicely in the centre of the modal.
Is there anything I can do to fix the address info window displaying blank on load ?
I added a height to the info window to fix it loading bank.
