MySQLi generates faulty code
Thread begun 2/11/2015 9:44 am by malcolm230194 | Last modified 2/16/2015 4:19 am by malcolm230194 | 3664 views | 6 replies |
malcolm230194
I've been finding that MySQLi generates errors and I'm having to go in and edit the generated code. Sometimes there is a duplication of part of the code giving the value from validated fields and sometimes the " character is randomly escaped as below.
$UpdateQuery->bindColumn("UserAddress1", "s", "".((isset($_POST["address1"]))?$_POST["address1"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("UserAddress2", "s", "".((isset($_POST["address2"]))?$_POST["address2"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("UserCity", "s", "".((isset($_POST[\"city\"]))?$_POST[\"city\"]:\"\") .\"", "WA_DEFAULT");
$UpdateQuery->bindColumn("UserState", "s", "".((isset($_POST[\"state\"]))?$_POST[\"state\"]:\"\") .\"", "WA_DEFAULT");
Have you any ideas regarding the source of this problem?
Malcolm
I am not able to reproduce.
What is your OS?
What version of DW are you using?
What Version of MySQLi are you using?
are you always using the signing bolt icon / bindings panel to select the form bindings? or hand coding some of them.
malcolm230194
MySQLi problem
OS is Win 7
DW is CS6 Ver12.0 Build 5808
MySQLi is Version 1.0.3
Yes I always use the lightning bolt and only hand code to remove errors.
I've just tried to edit an update server behaviour to test and have had the following sequence of events.
The MySQLi Update record window appears with a succession of error windows with a message
'It appears that one of your server-side values is improperly coded. Please check this interface for inconsistencies.'
The previously correct code is escaped starting at the fourth field.
Code fragment below is after correcting corrupted code using lightning bolt which just makes it worse.
$UpdateQuery->bindColumn("UserCity", "s", "".((isset($_POST["city"]))?$_POST["city"]:"") ."?$_POST[\"city\"]:\"\") .\"", "WA_DEFAULT");
$UpdateQuery->bindColumn("UserState", "s", "".((isset($_POST["state"]))?$_POST["state"]:"") ."?$_POST[\"state\"]:\"\") .\"", "WA_DEFAULT");
send a copy of the page please.
malcolm230194
File attached
yeah the problem is triggered by using the validated entries binding.
I think if you delete the column bidding that use the validated entries bindings, so in the page you have sent that will be lines 97 - 107:
$ConditionalQuery->bindColumn("OrderShipAddress1", "s", "".(ValidatedField("confirmiframe_562","shipAddress1")) ."", "WA_DEFAULT");
$ConditionalQuery->bindColumn("OrderShipAddress2", "s", "".(ValidatedField("confirmiframe_562","shipAddress2")) ."", "WA_DEFAULT");
$ConditionalQuery->bindColumn("OrderShipCity", "s", "".(ValidatedField("confirmiframe_562","shipCity")) ."", "WA_DEFAULT");
$ConditionalQuery->bindColumn("OrderShipState", "s", "".(ValidatedField("confirmiframe_562","shipState")) ."", "WA_DEFAULT");
$ConditionalQuery->bindColumn("OrderShipZip", "s", "".(ValidatedField("confirmiframe_562","shipPostcode")) ."", "WA_DEFAULT");
$ConditionalQuery->bindColumn("OrderShipFirstName", "s", "".(ValidatedField("confirmiframe_562","shipFirstName")) ."", "WA_DEFAULT");
$ConditionalQuery->bindColumn("OrderShipLastName", "s", "".(ValidatedField("confirmiframe_562","shipLastName")) ."", "WA_DEFAULT");
$ConditionalQuery->bindColumn("OrderShipPhone", "s", "".(ValidatedField("confirmiframe_562","shipPhone")) ."", "WA_DEFAULT");
$ConditionalQuery->bindColumn("OrderShipEmail", "s", "".(ValidatedField("confirmiframe_562","shipEmail")) ."", "WA_DEFAULT");
$ConditionalQuery->bindColumn("OrderShipCountry", "s", "".(ValidatedField("confirmiframe_562","shipCountry")) ."", "WA_DEFAULT");
$ConditionalQuery->bindColumn("OrderComments", "s", "".(ValidatedField("confirmiframe_562","comments")) ."", "WA_DEFAULT");
then open the server behavior to edit it, and reselect the form elements, it should work correctly.
malcolm230194
MySQLi problem
This post has been deleted.
